Engine stalls
/ Engine stalls #1
R Madison
Hello - I'm new to the site and I'm also a new owner of a '78 S650G.
The tractor starts, idles and runs perfect at higher RPM/s. The problem is getting it up to speed - it's hard to get it to take gas off idle. The only way to increase the RPM from idle is to SLOWLY give it throttle. Too much throttle too fast will stall the engine every time. After finessing the throttle to get the RPM/s up it runs perfect. Any Ideas?
Thanks!!
/ Engine stalls
Turnsout the points were just barely opening. Adjusted the points to .025 and it eliminated the stalling.
Any idea what the correct gap for the point is supposed to be???
Thanks,
Ron
/ Engine stalls #3
No , not really but about 15 would be better , 25 will give to much dwell angle . Check they are not pitted which makes setting with a feeler gauge impossible . If it uses a distributor put a couple of drops of oil on the felt pad in the shaft to lube it . Also a LIGHT smear of Petroleum Jelly on the cam lobes to stop the point rubbing block wearing out .
/ Engine stalls
Perfect. Thank you very much!!!
-Ron
2012 MACK GRANITE-GU713 (INOPERABLE) (A65643)
2012 MACK...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
2014 DRAGON  130BBL VACUUM TRAILER (A65643)
2014 DRAGON...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
