Engine Shutdown 4720.
/ Engine Shutdown 4720. #1
Red Horse
Bolton, MA
Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
I have a 2007 4720 cab which I bought with 215 hours- I now have 350. Shortly after I got it in January, I was plowing and got back on the machine and turned all the lights on. Engine shutdown immediately-like key was turned/fuel cut off. I monkeyed around the fuse panel and after a few minutes it started again-no issue. This has happened a couple of times since when while tractor was running, I would turn lights on and it would stop-last time it did it, I was quick enough to turn lights to off and it kept running.
Last week I had it at our fairgrounds where it plays a major roll in trash removal and one of my kids couldn't get it started-like dash lights come on but no crank. I had him push on all the fuse panels and it started.
The suspense is killing me! Any suggestions?
/ Engine Shutdown 4720. #2
Remove and clean all 4 battery cable connections. The battery ground cable is one of the most overlooked battery cables.
Thx Jim-will do-but if that were the issue, why would turning the lights on cause a shutdown?
/ Engine Shutdown 4720. #4
It could be the draw that the lights put on the electrical system.
The battery and/or it's connections are too weak to power the engine's electrical system and the lights at the same time. Clean the connections and top of the battery with a charger.
Thx-Cobra-that's two votes for the battery connector issue-that you John?
Pemberton Inc 416469 72in. Loader Forks and Frame (A64194)
Pemberton Inc...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
2011 JOHN DEERE 710J BACKHOE (A65053)
2011 JOHN DEERE...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2017 International HX620 Quint Dump (A62613)
2017 International...
