Mowing ENGINE RPM WHEN MOWING
/ ENGINE RPM WHEN MOWING #1
jdp
Southern Pines, NC
Kubota B 2320
I mow with a Kubota 2320 with King Kutter 5' finish mower. The PTO shaded area on tachometer requires an engine speed of about 2800 RPM. This RPM results in a relatively high fuel consumption. I have found mowing with 2000 RPM engine speed gives me good results, plenty of power/speed in mid gear range, and lower fuel use.
Is there any negative from mowing at this lower engine RPM? Shouldn't this also result in lower engine wear? Any technical info on this would be appreciated.
/ ENGINE RPM WHEN MOWING #2
Many mowers suffer a bad cut with anything less than PTO speed. If you are getting a good cut and not lugging the engine, nothing wrong with going with less RPM.
As far as engine wear, they are designed to run ad WOT all the time so you aren't damaging the engine running it at PTO speed and running a few hundred RPM less should be of no consequence good or bad as long as the motor is not too heavily loaded.
/ ENGINE RPM WHEN MOWING #3
If you look back, there are many threads on this subject...I think the general concensous is as Gary said...most run at full PTO speed. That said, Im usually about 300 rpms less than full PTO, unless in the heavy thick stuff.
/ ENGINE RPM WHEN MOWING #5
If I only had a 540 PTO I let the grass tell me what I have to do with the ground speed and engine rpms. As long as I know the engine is not lugging I tweak for what cuts/feels/sounds good. I don't worry about it.
Mark
/ ENGINE RPM WHEN MOWING #6
On my bush hog I run about 1800 rpm and that tackles everything- saplings to grass. 2400 is what I should use according to the manual and speedo but it feels like over kill when I do. For most everything, 1500 works great. I have a gear tractor - I wonder if that makes a difference.
/ ENGINE RPM WHEN MOWING #7
blade tip speed of a finishing mower... if the blades are not rotating fast enough, you may be bashing the blades into the grass and ripping the grass vs cutting the grass. and/or the vacum effect of various blades require a certain RPM / blade tip speed to pull grass up "example your tire marks in the grass" to pull the pushed down grass back up into the blades. possibly requiring an extra pass to cut the grass.
with above said, there is to much lawn that needs to be mowed here and i am not wanting golf course grass / lawn, but just wanting to keep things looking half way decent and keep the weeds in check. so tend to run at highest gear possible and highest RPM's i can on the mower. but i keep some lead way, in the throttle. so when i get into thicker / wetter grass, i can move throttle / rpm's up some vs down shifting into a lower gear to get through the given area.
other words find your sweet spot of tractor / equipment at a given ground speed for what the grass is like.
use it and abuse it, only comes with good maintenance of greasing all the zert fittings on the deck to checking all the fluid levels and filters as needed on the tractor.
other issues.....
if you are running finishing mower off of PTO, and hit a stick, and don't have a slip clutch inline with the PTO shaft or a "shear bolt NOT a regular bolt but a SHEAR BOLT" to protect your drive train, and already running engine low in RPM's greater chance of doing some sort of damage. granted belts on a finish mower should slip before damage to tractor, but if you have not hit a good size limb or ran over a brick or something... and/or going through thicker grass / taller grass and have not stopped the blades dead in there tracks, you haven't been mowing.
/ ENGINE RPM WHEN MOWING #8
I have been mowing at less than rated full PTO RPM for years. The yards always looks fine, my equipment has never been damaged & I have used a lot less fuel.
/ ENGINE RPM WHEN MOWING #10
I've found most jobs can be accomplished quite nicely at 1700 to 2000 rpm in midrange on my MX5100 with 72" roughcut or tiller, and for my 84" boxblade, same rpm in low range
/ ENGINE RPM WHEN MOWING #11
What I would like to see is an honest to God scientific like comparison on this.
I have always heard that sharp blades are better and that faster blade tip speeds are better but I have only seen opinions on this.
Does it hurt the grass blade if it is ripped rather than cut? Wouldn't a dull blade still "cut" the grass if it is going fast enough? How sharp is sharp? Does a high suction blade versus a low suction blade really make any difference? These are the questions that keep me awake at night :)
Me, I have a six-foot rear discharge Woods rear finish mower that I use between 2000-2200 rpm's (PTO is rated for 2500). I can't tell the difference in the cut at those RPMs versus 2500. At 2500 RPMs the mower starts to sound angry though.
/ ENGINE RPM WHEN MOWING #12
Different times of the growing season produce grass that doesn't always behave the same when being mowed. Add to that the height of the uncut grass is always different and I find myself discovering ideal mowing RPM's being different by a few hundred. Best to be observant and flexible to adapt to the conditions.
I only recently discovered a way to deal with a small windrow problem I'd been experiencing in some taller grass. The first 23 years we lived here I only used 5' decks with a right side discharge. Even when we got the 6' RFM with a rear discharge, I more or less continued a counter-clockwise direction out of habit. On the taller and thicker grass the deck was leaving small windrows of cut grass at the right side of the cut.
Then I started mowing in a clockwise direction and the windrow problem was eliminated. With each pass, the little line of grass disappeared and a new one was laid on the right. It didn't accumulate and grow in volume, it was more as though it just moved over a notch as I went. Last pass directly over the line at low RPM's erased it.
Case IH Farmall 70A Tractor (A64047)
Case IH Farmall...
2020 DRAGON 150BBL ALUMINUM (A63569)
2020 DRAGON 150BBL...
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
Atspower Mini Excavator (A60352)
Atspower Mini...
2025 Swict 78in. Bucket Skid Steer Attachment (A61572)
2025 Swict 78in...
Deere TR48B Worksite Pro Trencher (A64047)
Deere TR48B...
