Engine Removal
/ Engine Removal #1
Rgillard
Ireland
Fiat 82-94
Myself and my Brother got some time to remove the engine from my old car for my off road buggy. We lifted the engine with our home build gantry crane and 2 tonne lifting block. The engine is a 1.3L nissan sunny engine and will hopefully give the buggy plenty of power. it was a cheap option as the car was off the road and being sent for scrap.
/ Engine Removal
Crane ready for the lift
/ Engine Removal
Engine connected and ready for final bolts to be removed
/ Engine Removal
Bingo. Now we will get the car out of there and move the buggy under the engine and get it securely mounted in it...
/ Engine Removal
Forgot to attach the pictures
/ Engine Removal
view from back
/ Engine Removal
Buggy awaiting Transplant
/ Engine Removal #8
I'm making a buggy with my friend, using the complete front end of my old car, a Volvo 440 Turbo Diesel. We use the complete subframe that carries engine, transmission and wheel suspension. We bought another 1.7 injection automatic, to get another subframe, which has the engine and trans removed. All we have to do is weld a frame and attach both subframes to it with 4 bolts each. Then 4 mounts for the telescopic spring carriers and we're done.
I wanted to use the diesel engine of my old car instead of the gasoline, which may be a bit more live because it doesnt have the slight turbo lag as the diesel has, but it saves us quite some $$$ when using daddy's dyed tax free agricultural diesel instead of buying petrol for 1,50 Euro per liter, and with the diesel we dont have to mess with electronic injection and ignition.
This engine puts out 90 hp and has a nice flat torque curve from 2000-4500 rpm, like an off road vehicle should have. The original car weighed 1033 kg and was quite quick, my current 440 TD is slower and is only doing 185 km/h as top speed where the old one did 200 km/h
With a pipe roll cage and square box tube frame rails, i expect the weight to be less than 600 kg, running on the original 1033 kg car suspension, which means it's going to be as fast as a brand new Golf GTI and with anti-roll torsion bars on both front and rear axle (we use two front suspensions, front and rear) we should be able to stay way ahead of the police in case we might get chased.... :D
I think we need to pour some concrete in the front of the buggy because all the weight is in the rear end, maybe it will take off on its back wheels too easily... ???
Oh and maybe we'll close that waste gate a little bit to raise the turbo pressure... 120 hp is possible ;)
/ Engine Removal
Any Pics Renze. Sounds like an interesting Buggy
3 Propane Bottles (A65579)
3 Propane Bottles...
100 gal L Portable Fuel Tank (A66408)
100 gal L Portable...
Kinze KPM3 Planter Monitor (A65640)
Kinze KPM3 Planter...
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
2017 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A64556)
2017 Ford F-550...
Little Standing Horse Statue (A65583)
Little Standing...
