Engine question
   / Engine question #11
Don't have any "nut" on the fuel line on my tractor. Just a bolt going through the banjo fitting into the lift pump on one end and into the fuel filter base on the other end.
   / Engine question
It sort of looks like a banjo bolt only it has a slot in the hex head for a screwdriver. The nut is tightened against the banjo fitting. It appears the bolt is used as some sort of adjustment as it can be screwed into the pump housing.
   / Engine question #13
There is a spring and a ball under there, inside the banjo bolt that act as a check valve. If you ever have one that runs for a second, then stops, and when you work the hand pump and it pumps up and gets hard, than be sure someone didn't move this to the line on the back side of the injector pump head. One of my ex employees (this was not how he achieved "ex" status) changed an injector pump and we spent two days trying to figure out why the tractor would start then die... it belongs on the end closest to the radiator
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56438)
2022 John Deere...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
