engine oil options
/ engine oil options #1
cptdave
New Hampshire
Kioti CK-20,Wheelhorse 4-14-8
What engine oil do you use in your CK-20?
/ engine oil options #2
I used Mobil Delvac 1300 Super SAE 15W40...from Walmart.
/ engine oil options #3
You can use just about any oil marked Diesel that has from rating of at least CD. You may go up, CE, CF etc. Here's a good article on diesel oils. John
Diesel oils
/ engine oil options #4
</font><font color="blue" class="small">( I used Mobil Delvac 1300 Super SAE 15W40...from Walmart. )</font>
"Used" or still use?
/ engine oil options #5
I USED it at the 50 and 100 hr service...and most likely will USE it at the 200 hr too...so i guess you can say I USE it... /forums/images/graemlins/grin.gif
KJ, Does that apply to synthetics ie,Shell Rotella 5w-40?
/ engine oil options #7
/forums/images/graemlins/cool.gif Gotcha.
/ engine oil options #8
I personally wouldn't use anything less than 10W40 in warmer weather, and do use 15w-40. The only real advantage I see in the synthetic is if you're not going to use the tractor and change the oil often enough to avoid chemical change damage. Regular oil I would change every 4-6 months regardless of use, but with synthetic, that would not be neccessary. The owner's manual does not have anything at all about synthetics, but they do recommend 10w40, no 5w. You might right to customer_service@kiotitractor.com and ask them about it. John
/ engine oil options #9
</font><font color="blue" class="small">( Does that apply to synthetics ie,Shell Rotella 5w-40? )</font>
I run Rotella T 5w-40 synthetic in my DK 35. Works fine !!
Thanks,KJ. I will post their reply. Dave
As of yet customer service isn't answering their mail. I resent the email and also asked when the backhoes are going to be in New Hampshire.
/ engine oil options #12
I know that recently they were doing an inventory, and there was something else going on the other day and they weren't even answering the phones. Can't remember exactly what that was, but my dealer is trying to find out an ETA for my backhoe and others. I'll post if I find out anything. thanks, John
/ engine oil options #13
how does that song go? --- "you go further down the row with Shell Rotella"
I would recomend Rotella, or Delvac, or Dello.
2011 CATERPILLAR 279C SKID STEER (A65056)
2011 CATERPILLAR...
3146 (A63117)
3146 (A63117)
2003 Toro Workman 2110 Gas Utility Cart (A66734)
2003 Toro Workman...
2009 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2009 INTERNATIONAL...
2020 VOLVO VNL760 SLEEPER TRUCK (A59914)
2020 VOLVO VNL760...
2008 FORD F150 EXTENDED CAB PICKUP TRUCK (A66091)
2008 FORD F150...
