engine / oil leak
/ engine / oil leak
Hi Tim,
Thanks for the response. I had read that thread earlier, but was unable to open the document listed. I actually just want to "tow" it onto my trailer which is right next to the machine. My problem is finding and/or opening the tow valve. I believe I am trying to open it (in the correct direction) but it won't budge. Is there a trick?
/ engine / oil leak #12
When my coil was out I just used the starter to move the PT about 50 ft. I just held the peddle down while cranking the engine.
/ engine / oil leak
Thanks for the suggestion about using the starter. It worked perfectly to get the PT onto my trailer. Hopefully I will find out in a couple days what went wrong with the engine.
/ engine / oil leak #14
Just a note on using the starter to move it. Take your time, don't crank it too long and let it rest between cranks. They are easy to heat up and damage.
Glad you got it on the trailer. Hope it turns out to be something simple (and cheap!). :)
2006 Nissan Frontier Ext. Cab Pickup Truck (A59230)
2006 Nissan...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
2020 Ram 3500 4x4 Ext. Cab Pickup Truck (A59230)
2020 Ram 3500 4x4...
2017 Rogator RG1300B Dry Fertilizer Applicator (A61307)
2017 Rogator...
KAESER COMPRESSOR (A60736)
KAESER COMPRESSOR...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2020 Chevrolet...
