Oil & Fuel Engine Oil for JD 110TLB
   / Engine Oil for JD 110TLB #1
CurlyDave
Elite Member
Grants Pass, OR
JD TLB 110
The time for an engine oil change has come, and when I look in the manual I find the attached, highly educational diagram.
It is easy to understand, except for the fact that there are no numbers on the thermometer in the diagram.
Does anyone know either where the numbers are supposed to be on the diagram, or even what the operating range of 15W-40 or 5W-30 is in my machine?
   / Engine Oil for JD 110TLB #2
Dave, for summer use use the 15/40 or a straight 30 is my prefered oil for your 110. If you were using it for snow removal the 5-30 or 10 weigh would be the best.
   / Engine Oil for JD 110TLB #3
I'll be.. I thought for a moment that you were given a "defective" manual by your dealer! Only to discover that I have the same manual...
They blacked out the temps on the thermometer scale! :confused:
Isn't that "special"?!? Gonna have to take a peek at my Technical Repair Manual and see if the "data censors" were at work editing that as well.
I've been using Mobil 1 Turbo diesel 5W-40 for late fall - winter use. Spring - summer (you're likely Springing, now: it was -9F here this morning) use I've been using Rotella 15W-40.
The local JD dealer has offered to sell me the JD synthetic for $20/gallon. I may switch over this next fall.
AKfish
   / Engine Oil for JD 110TLB #4
I use Delo 400 15w/40w year round in southern New Mexico.
Steve
   / Engine Oil for JD 110TLB #5
I ended up going with the JD 5-40 synthetic...Price isnt bad and its good year-round.....
AKFish, is that in a Gallon jug? I paid 5.25ish per quart....Which isnt bad IMO.
   / Engine Oil for JD 110TLB #6
i will be using Amsoil 5w30 syn 3000 it has very high levels of phophourus and zinc,i have been using this same oil in my 7.3l ford truck for 6 years with good results winter and summer.Also can extend drain intervals with an Amsoil filter.Right now a gallon is around 41.00,but it is great oil, full synthetic
   / Engine Oil for JD 110TLB #7
CurlyDave et al,
Does this help?
Joe
Thanks Joe.
I printed that out, cut the paper down to size, and it is already in my manual. Looks like the 15W-40 will do the job for any temperature I will encounter in Southern Oregon.
Just out of curiosity, what is the language in your signature?
   / Engine Oil for JD 110TLB #9
Not sure... I've still got a few gallons of Mobil 1 and Rotella to work thru. But with the Ford 7.3 and the DuraMax competing with the 110 for oil changes - it goes pretty quick.
I wanted at least 5 gallons and will buy 10 for the $20/gal. Maybe that's why they'll sell for that..
I'll ask them the next time I stop in. Their price is about $6 a gallon less than Wally's for the Mobil 1.
AKfish
   / Engine Oil for JD 110TLB #11
CurlyDave,
You're welcome!
The language is Arabic. (It's a well known message to the world.)
Joe, thanks. Where did you find that chart? Your manual? Dave and I must have the "braille" version...
AKFish,
I located it in lubricant (oil) information from the JD website:
Oil, lubricants, and accessories Features and benefits
Oil, engine, Plus-50 15W-40 and 0W-40
Plus-50 and Plus-50 Synthetic Engine Oils
https://jdparts.deere.com/partsmkt/document/english/pmac/5565_fb_Plus5015W40_0W40.htm
You will have to read down through the page until you come to the section entitled "Air Temperature Chart."
L8r ya'll,
Joe :D
P.S. I believe it to be in my manual also ....
2023 LEEBOY 8530 ASPHALT PAVER (A60429)
2023 LEEBOY 8530...
Brent 420 Grain Cart (A61307)
Brent 420 Grain...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
2020 CATERPILLAR 242D3 SKID STEER (A60429)
2020 CATERPILLAR...
