Engine knocking ..bang bang bang..
/ Engine knocking ..bang bang bang.. #1
olink
Looking for help in diagnoses before I tear into this thing. Have a FarmPro 2425 with Y385 engine. Most recently been grading and land clearing. Have a couple of small hydraulic leaks, so before the long day began, I topped off the rear Hyd for the drag box operation. Just a few minutes into working, I backed into a stump and bent dragbox braces and stopped the engine while I attemped to straighten braces. Needed tools, so I headed back to the garage with the tractor. About 100 yds later, the engine started a load knocking. I shut it down immediately. checked oil and found it to be about 2qts high...over filled. Drained the oil and put in new oil to proper levels. Started just fine, but the loud knocking continues. Never got any indication of overheating, had good oil pressure. Engine only has about 40 hours on it. I used to rebuild VW engines as a young man, kind of sounds like I dropped a valve? I have absolutely NO experience with diesels. Anyone want to give me a starting point? Pull the valve cover? Or could this be some sort of a fuel issue causing the knocking?...like a misfire? Oh, tractor is out of warranty, bought in April of 2003. Suggestions/comments very welcome and much appreciated. OLY
/ Engine knocking ..bang bang bang.. #2
Oly, how did it get overful on oil? I wonder if it got in through the hydraulics somehow. I have no clue on what could have happened, maybe Greg or Chip will be able to help. Sorry
/ Engine knocking ..bang bang bang.. #3
Olink,
If you were sure the original oil level was correct, ie: you did not originally over fill the crankcase and was found to be significantly above the fill level, then you can narrow it down, there are only so many fluids in the tractor.
1) Smell the oil..... if it smells like diesel, you have fuel leaking into the crankcase... bad seal, injector pump... something...
2) If it appeared to be seperated...maybe coolant... again smell it... if it had normal antifreeze, it will have a pungent, almost sweet smell and you should see the coolant float on the oil. Again, it is a front seal or cracked block letting the coolant from the block into the crankcase.
3) If you see two grades of oil... again some separation of oil, heavier engine oil and thin oil ( it could be Hydraulic oil) let the oil settle out, in a clear container... the lighter hydraulic oil should rise to the top and you will see the gradiant separation... Not sure the old smell test would work on this check.... Again, some seal has blown to allow the mix... Check the level in each of the above reservoirs, it may also give you an indicaton the the mysterious fluid....
You can then go from there on repair, based on the fluid type...
/ Engine knocking ..bang bang bang.. #4
</font><font color="blue" class="small">( the engine started a load knocking. I shut it down immediately. checked oil and found it to be about 2qts high...over filled. )</font>
First guess is hydraulic pump seal blew. Check your hydraulic reservior, see if it's down about two quarts.
//greg//
/ Engine knocking ..bang bang bang.. #5
Especially, if after running again, it is high on oil and hyd tank is low. Fuel and coolant are possibilities, but the most commmon is the hhd pump seal goes, and the hyd oil fills the engine. See: this web page
/ Engine knocking ..bang bang bang.. #6
I like all the suggestions so far. these things are pretty tough tractors but have a few weaknesses. the Hyd Pump seal & primary pump line routing is one of them. the QD from the pump the the FEL may have came loose this blows the seal and dumps hyd fluid past the seal into the crank case by means of the common pump drive gear to engine crank gear that are actually in the engine crank case.
one quick check is to see if the hyd sstem is still working. if it is then the QD may not be the problem but somethign farther down line. I have not checking in the valve cover on mine, (neglected the 50 hr service of valve lash adjustment and head bolt re-torque.) thew injection pump shouldn't get fuel into oil, but it does fet fuel into the injection pump oil. (see johnS's site as linked above.) read all that info there and get the recogmended things done... the rest is minor tune up stuff nad common since running. these engines are not some high tech honda miltiport 30 valve thing... just more like the old 50's tech pretty similar to the VW ones of past...
others have described a fuel problem similar to this but not WITH the engine oil over fill probl.. the guys here and at NYCTOA site are great info and will help in any way possable.
MarkM /forums/images/graemlins/smile.gif
I overfilled the hyd res about an hour prior to this occurance. I'm pretty sure it has something to do with that since the res is low again. I have a couple of small leaks and since I was headed out for the day with the tractor, I thought a bit over fill wouldn't hurt??? Thanks for the reply..sorry I didn't get back sooner, been busy with the military...
Sure appreciate you replying. I've been busy with military stuff and haven't been able to get to the tractor repair. I'm sure the oil level was correct, because I check it everytime I use the tractor and I had just changed the oil about 3 weeks before (6 hours). I saved the oil from this occurance, so I will check to see if there is any separation of fluids. I'm thinking this is a blown seal between the hyd pump and crankcase? I don't have a good repair manual, so I don't know the different paths hydro could take into the case, but That seems to be a logical starting point. Thanks for your patience on my reply. I'll let you all know what I find out. It's raining like crazy here today, so this may be another delay day!
Greg, the hyd res is definitely low... and I don't see any major spills on the ground between the garage and the work site (about 300 ft away) so, I think you have hit it on the head! Probably the seal between the pump and the case. Thanks .
/ Engine knocking ..bang bang bang.. #10
Let's hope you didn't do any serious damage to your tractor motor.
Awsome! This will be the first thing I check. All my lines are still in tact, but the blown seal is sure right on tract for my problem. Thanks for the link. I think the pics will help me more than anything else since I don't have a shop manual. Thanks again. I'll post when I'm finshed witht the diagnoses...Thanks again.
Thanks for the other leads for help. I'm going to go try removing the pump and see if the seal is gone. From everything that has been written here, that seems to be the most likely problem. Of course, it is raining really hard this morning, so I will be delayed yet again... been really busy with the military this week so I haven't even had a chance to raise the hood on the tractor..let alone bust bolts!
Thanks Oly
Yah, that's what I'm affraid of. I over filled by accident, but thought...no big deal, it'll leak out ....well, it did...probably thru the seal!... just my kind of luck though. Pray for me!
/ Engine knocking ..bang bang bang.. #14
Don't beat yourself up about the hydraulic overfill. Excess will normally just blow out the vent. Until a seal goes that is. The hydraulic pump has a pressure seal around the pump shaft. When that ruptures, there's nothing to stop hydraulic fluid from flowing into the crankcase. This has happened to several owners when the quick disconnect coupler "uncouples". If Jinma had engineered in a relief valve, this would be a non-problem. But that's the topic of another discussion.
"Deadheading" is when the pump is being overworked trying to push hydraulic fluid into a blocked path. The engine hammers and bellows black smoke, trying to turn a highly resistant pump, that's trying to push fluid that's go nowhere to go. The fact that you just experienced a problem involving the rear hydraulics (TPH) introduces additional possibilities, but they all still point to the pump.
If my assumption is correct, I think you may end up buying a new pump to fix this problem. Then you could take your time finding somebody to see about repairing the old one. Nice to have a spare on the shelf - for "next time".
It should go without saying, but you should replace the oil filter and change the oil as well.
//greg//
/ Engine knocking ..bang bang bang.. #15
Olink,
As weird as it may sound. Before you buy a new pump, try to tighten the mounting bolts first. I thought I had blown a pump, purchased a new pump, pulled off the old pump only to have then relized that the old pump bolts had loosened up. the gasket had not blown only the contact seal. Even if it is the pump, they are not expensive.
/ Engine knocking ..bang bang bang.. #16
Olink,
Whew....Your much better off that it was Hyd. Oil... /forums/images/graemlins/smile.gif At least is still a lubricant and based on the limited time you ran it in the motor after noticing the problem, you should not have caused any damage.... You will however want to "flush out" that oil once you have the repair seal isolated and fixed.
Once you have the repair done, I would run some new diesel oil through for just a couples of minutes to warm it up and mix with any Hyd. Oil in the system..
Make sure you have corrected the problem, ie: no more fluid transfer.... then drain again and refill with new oil... then keep checking it regularly....
If it had been coolant or fuel, much more problems as those materials are far less able to provide adequate lubrication to the vital components....
Hope your repair goes well....
/ Engine knocking ..bang bang bang.. #17
I recommend getting a new pump and a rebuild kit for the one that failed. Do not make the mistake of just trying to replace the shaft seal. It will blow out immediatly. Here is a web page on pump disassembly.
The question that is unanswered is "why" did the pump go. As Greg said, the usual cause is the quick disconnects. Doesn't sound like that was the case, but recheck them. Overfilling the hyd tank shouldn't cause it. It would cause some spewing out the vent and some lubrication and rust preventative measures for the back of the tractor /forums/images/graemlins/smirk.gif I am suspicious of the impact, but I am not convinced it would put that kind of pressure on the hydraulic system at the pump.
Anyway, be careful on the first start-up after the repair, and oil/filter change. If the pump is still dead headed, it should be hard to turn over and if it starts, you should be able to sense it is under heavy load. Shut it off immediatly, or you will loose another pump.
/ Engine knocking ..bang bang bang.. #18
We have the hydraulic pump repair kits in stock ,in the kit is the pump seal also,let me know if we can help.
Tommy web page
MACK SINGLE AXLE(INOPERABLE) (A67714)
MACK SINGLE...
2021 CHEVROLET SILVERADO 3500HD SERVOCE TRUCK (A67714)
2021 CHEVROLET...
2017 GMC Sierra 2500 HD 4x4 Crew Cab SpaceKap Service Truck (A66736)
2017 GMC Sierra...
2012 Honda Crosstour Hatchback (A66738)
2012 Honda...
Sandblast Skid (A68134)
Sandblast Skid...
2008 FORD F150 EXTENDED CAB PICKUP TRUCK (A66091)
2008 FORD F150...
