Engine Breakin On New Tractor
/ Engine Breakin On New Tractor #1
digicamnut
South East Teaxs
Anyone got any tips on the break in on my new L3400? I wan't to do it right the first time.
Craig
/ Engine Breakin On New Tractor #2
Diesels need to be worked harder than gas engines on break in. Mow some normal thickness grass for a couple hours, use a back or box blade, do some FEL work. Full throttle is ok, but full load is not ok. That means don't do stuff like pull a 2 bottom plow thru hard pack.
Just watch the temps, keep the screens clean and fluids full. Operate for 1 hour - check stuff (visual inspect for bad stuff happening). Operate for 2-3 hours - check stuff. Let it cool - have a lunch break or an adult beverage. Check wheel torques, FEL frame bolt torques, tire pressures, fluid levels, cleen screens and go back to work.
If you baby a new diesel, you are more likely to harm it than operating it at 70-80% of max load. I like to change engine oil at 10 hours on a new or rebuild.
jb
/ Engine Breakin On New Tractor #3
I have found that "operating it as you plan to use" it is good advice but avoid the really heavy lugging already mentioned and don't let it idle too long. Vary the engine speed. Just like a car.
I also leave the original oil in for the first 50 hours just in case they used some special oil or additive for break-in. I'm not sure on this part but the book says 50hours so and I do it.
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
Athey 7-12D Force Feed Loader (A62679)
Athey 7-12D Force...
2007 WESTERN STAR  4900 SB (A65643)
2007 WESTERN STAR...
2016 Komatsu WA320-8 Articulated Wheel Loader (A64553)
2016 Komatsu...
