engine blow by
/ engine blow by #1
firebird93
jtown, ky
kubota bx2350hst Kubota b2400hst Mahindra 6065 pst
i have been looking into an older b series tractor (a b2100 and 2400) and have found 2 that i am interested in.
one has 1100 hrs the other less then 500 but both have what i call blow by when they are idling.
they have a tube that goes from the valve cover down to the bottom of the engine and this is where
it comes out. i have a newer bx and thought i would look at it but it doesn't have that particular tube.
it has a tube going into the intake. normally i associate blow by with wear but at the hours on these 2 machines
that shouldn't be an issue. my question is: is this normal for these older b series tractors??
/ engine blow by #2
I've seen brand new engines wiped out w/ 10-20 hrs on them.. & just huff'n oil outa the tube..
. DONT base the blow-by on the low hours.. {"that shouldn't be an issue"}..
Pull the air cleaner & tap the filter on the ground & watch for the dust..
Take your hand & wipe it in the air cleaner hsg..
Pull the dipstick & oil fill cap while its running.. if its "puffing smoke" outa those 3 places.. I'd walk away.
/ engine blow by #3
If its got puke tube, basicly a valve cover vent i would expect it to puff a bit. Theres massive amounts of air and pressure/vacuum movement in an engine.
Newer engines dont have this for emissions, or it could dump back into the intake.
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A61568)
2015 Ford F-150...
UNUSED IRANCH IRET13 ELECTRIC TRICYCLE (A62130)
UNUSED IRANCH...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61568)
2015 Chevrolet...
2006 NORAM 65E MOTOR GRADER (A62129)
2006 NORAM 65E...
UNUSED KIVEL MINI SKID STEER HITCH ADAPTER PLATE (A62130)
UNUSED KIVEL MINI...
