Engine block heater part 2
/ Engine block heater part 2 #1
cchoate
Near Buffalo, NY
Kubota GL3430 HST
I spoke with my dealer today about getting a plug heater installed on my 7500. (I am using a magnetic heater on the oil pan now.) He says heaters are not really needed anymore on todays engines both gas and diesel. Letting the engine warm up while idling is the way to get to operating temp. He hasn't installed a block heater in 5 years on any newer tractor. I would suspect he could make some money selling and installing them, so I do believe his logic. I will continue to warm my oil a few hours before I start it which he said was a small help.
/ Engine block heater part 2 #2
<font color=blue>...He says heaters are not really needed anymore on todays engines both gas and diesel...</font color=blue>
...and this dealer services Buffalo, NY area with your temps and snowfalls...? /w3tcompact/icons/blush.gif
Maybe I'm from the old school, but that block heater is much more effective than any magnetic heater I've seen... /w3tcompact/icons/smile.gif
/ Engine block heater part 2 #3
Hmmm....my Kubota dealer says he never ships out a new tractor without a block heater in it. He indicated that for the few dollars it represents it can make a big difference. I certainly got one!!
Kevin
/ Engine block heater part 2 #4
Up here when it gets really cold without a block heater my tractor probably would not start on some days. Need the heater just to get it going.
Ken
/ Engine block heater part 2 #5
Cchoate. Hmmm.... that is an interesting perspective that your dealer has on block heaters. I stopped by a Southern Minnesota New Holland dealer last weekend, and asked him (one of the owners) about block heaters. His statement was that a tractor never leaves his dealership without one installed. I've had a couple of diesel trucks now and have always felt that until they get up to operating temp, you are incurring the most wear on the engine. Matt.
/ Engine block heater part 2 #6
I've got mine, Installed it myself on the 2710. I love it. I feel better knowing that the block is warm enough that the oil pump can do its job. We have been in a cold spell here in Saratoga NY. It is been -10 and -20 every morning for the last week.
/ Engine block heater part 2 #7
Chris -- IMO that's just plain bad advice. I see you also live in the snowbelt. Having had tractors both with and without block heaters I now consider them standard equipment.
Pete
/ Engine block heater part 2 #8
Just bring the dealer and his diesel to Edmonton. -39 C this morning and see how the diesel starts. If'n it will even turn over.
Not good advice. Install and use the block heater in cold weather as it saves much wear and tear on the engine.
Egon
/ Engine block heater part 2 #9
jasonf,
was it a hard install ? i just ordered one from carver. They faxed me the instructions. it seams easy enough but, they talk of cutting the 1/2" rubber line going to the radiator. what is the 1/2" line for ? any advise or tips would be appreciated. pics?
/ Engine block heater part 2 #10
Egon,
Are you still hanging out here in Edmonton? You keep this up and I'll have to have you out to get some seat time /w3tcompact/icons/wink.gif.
Kevin
/ Engine block heater part 2 #11
Kevin:
We be leaving for home tommorrow morning.
Ahh-- I've spent my seat time at the -30's temperature so I'll pass on that.
The driveway back home has 5 foot drifts on it just waiting for me.
Egon
/ Engine block heater part 2 #12
Egon,
<font color=blue>Ahh-- I've spent my seat time at the -30's temperature so I'll pass on that. </font color=blue> Darn, I can't con anyone to take the seat time in the -30 temps! /w3tcompact/icons/wink.gif
I'd love to see some pics of your 5' of snow. Sure wish we were a little closer to even 1/2 of that here!
Have a safe trip home.
Kevin
/ Engine block heater part 2 #13
If its the standard kubota block heater there is no line to cut. Remove the threaded plug and install the heater.
/ Engine block heater part 2 #14
Thank's Kevin.
Will try and get a picture when we get home.
Must be some ambitious young fellow you can con into seat time. But actually your tractor will also prefer to wait for a little warmer weather.
Egon
/ Engine block heater part 2 #15
<font color=blue>they talk of cutting the 1/2" rubber line going to the radiator. what is the 1/2" line for ?</font color=blue>
Sounds as though they are selling you a coolant heater, not a block heater.
KUBOTA 30" EXCAVATOR BUCKET (A64280)
KUBOTA 30"...
CASE IH 290 AFS MAGNUM TRACTOR (A64280)
CASE IH 290 AFS...
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
(8) PALLET OF DBL DISC FERTILIZER OPENERS (A63291)
(8) PALLET OF DBL...
