Engine 3T75U
/ Engine 3T75U #1
jlinn1
NE Nebraska
Yanmar 1610D
Does anyone know if there is a John Deere tractor that uses the YM 1610D engine with the Engine code, 3T75U?
I would like to get a screw in Block Heater and thats the best option I can think of...
Justin
/ Engine 3T75U #2
I have a ym2002 with the 3T80u engine, which is the same as the JD750. If you are ambitious, Pull your plug out and measure it, and I can measure mine and let you know if I think it will work. I just installed it about 1 month ago, and it starts like it's summer (single digits here)
/ Engine 3T75U #3
If your block has a screw in freeze plug, the Yanmar block heater should work. I'd recommend trying to loosen the plug before ordering it. Sometimes they are really hard to loosen.
/ Engine 3T75U #4
I let mine soak with PB on it overnight, and then had to run it for about an hour (working). That let it get nice and warm, and then put a rachet and extension right into the square hole and came right out! The heat must have axpanded it just enough. Must have been lucky.
2006 Chevrolet Silverado 2500HD Ext. Cab Knapheide Service Truck (A61573)
2006 Chevrolet...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
UNUSED 1RANCH 1RET13 ELECTRIC TRICYCLE (A64280)
UNUSED 1RANCH...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
2006 GMC W4500 10ft Box Truck (A61573)
2006 GMC W4500...
