Empty Lever Slot on BX2200
   / Empty Lever Slot on BX2200 #1
Anonymous Poster
Epic Contributor
I have an empty slot to the rear of my 3pt lift on my BX. It has a picture of a hydraulic cylinder, extended and retracted. Is this for one of the fascinating but unknown options or is it just a case of using one panel for lots of tractors (sniff sniff).
I was thinking of a cylinder on the rake would be nice. Is there an easy way to tap in to the system?
I'm still looking for the 4 foot backhoe!
   / Empty Lever Slot on BX2200 #2
It should be a slot for a single remote valve lever. All you have to do is buy the remote valve, remove the plate where it goes on the side of the transmission case, install it, and hook it up to the cylinder. /w3tcompact/icons/smile.gif
Mark
I have a snowblower ordered for my BX2200. Is this where the lift cylinder lever will go? I was lead to believe it is the same lever as used on the loader and hangs off the side of the tractor.
   / Empty Lever Slot on BX2200 #4
If it's a front mounted snowblower, no. You'd use a fender-mounted remote joystick, which isn't the same as the remote valve option used for rear-mounted hydraulics.
Mark
2014 Ford F150 4x4 Crew Cab Pickup truck (A55973)
2014 Ford F150 4x4...
2021 Kubota SVL75-2 Track Loader (A55315)
2021 Kubota...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A56435)
2021 John Deere...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
202475 (A54757)
202475 (A54757)
