Empty Lever Slot on BX2200
   / Empty Lever Slot on BX2200 #1
Anonymous Poster
Epic Contributor
I have an empty slot to the rear of my 3pt lift on my BX. It has a picture of a hydraulic cylinder, extended and retracted. Is this for one of the fascinating but unknown options or is it just a case of using one panel for lots of tractors (sniff sniff).
I was thinking of a cylinder on the rake would be nice. Is there an easy way to tap in to the system?
I'm still looking for the 4 foot backhoe!
   / Empty Lever Slot on BX2200 #2
It should be a slot for a single remote valve lever. All you have to do is buy the remote valve, remove the plate where it goes on the side of the transmission case, install it, and hook it up to the cylinder. /w3tcompact/icons/smile.gif
Mark
I have a snowblower ordered for my BX2200. Is this where the lift cylinder lever will go? I was lead to believe it is the same lever as used on the loader and hangs off the side of the tractor.
   / Empty Lever Slot on BX2200 #4
If it's a front mounted snowblower, no. You'd use a fender-mounted remote joystick, which isn't the same as the remote valve option used for rear-mounted hydraulics.
Mark
2021 Ram ProMaster City Van (A56858)
2021 Ram ProMaster...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56435)
2019 RAM 5500...
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
2015 Nissan Altima Sedan (A54815)
2015 Nissan Altima...
2012 International Prostar (A56435)
2012 International...
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
