Emergency Generator
/ Emergency Generator #31
I purchased the Honda 750 at Costco two years ago and absolutely love it. I've only charged the battery one time when I first purchased it, and run it about once a month for 20 minutes. It is very quiet considering the size of the motor, will run 7 hours on a tank of fuel, and starts on the first turn of the key, or if you pull start it, it will start usually on the second pull. I purchased a sub panel for the generator at Home Depot, and had an electrician install it and set up the breakers for about $100.
Costco will stand behind anything you buy, but if you have a choice on generators, you can't beat a Honda motor.
/ Emergency Generator #32
It's also possible to feed your house by "back-feeding" through your dryer, stove, or welder receptacle, but I wouldn't recommend it. There are two serious pitfalls to this approach, one is that you have to ensure the main power breaker is OFF before you connect the generator. It doesn't sound hard to remember, but it happens. A set-up like techman posted eliminates that possibility.
The second pitfall, and one that is potentially lethal, is that unless you completely disconnect the power feed from the utility to the main panel, it's possible under the right conditions to feed power back through the ground wire to the grid. Step that up through a transformer on the pole outside your house, and it gets really nasty. A repairman on a pole two blocks away can get a fatal shock from your generator.
With most main breakers on distribution panels, opening the breaker only opens the two "hot" leads, and does nothing with the ground wire. What the specific conditions are for this to happen, I can't say for sure, but I've been told that by people that work around this stuff for a living. I believe them.
The commercially available generator sub-panels and the Generlink break all three wires entering your house, two of those being live 110v to provide 220v service, the third being the ground wire to prevent that possibility.
Sean
/ Emergency Generator #33
Sean
I may be totally mistaken, but I do not think there is a ground wire coming in to a house from the power company. The way I understand it is there are two 110 hot leads and one neutral lead.
Please correct me if I am mistaken. :confused:
/ Emergency Generator #34
Yep, 2 hot and a neutral. That's how it is at my house. The house panels are grounded to at least two copper rods driven into the ground outside.
/ Emergency Generator #35
Sean
Do that in this area and be ready for HUGE Lawsuit if someone gets jolted, yes people backfeed thru dryer plugs and such but it is illegal here......besides if you don't limit what is turned on for your generator then you can overload you equipment.....and yes the transformer out on the pole boosts your 220v to much higher voltage when it goes backword thru to the grid........OUCH!!!!
Best to just do it right:thumbsup:
/ Emergency Generator #36
Check out the Gentran Vintage transfer switches. They are very easy to install and can be had for less than $150. Also sold under the name Reliance, for more $
/ Emergency Generator #37
I put in a Reliance from Home Depot (Lowes sells it also) for under $300. with everything to hook it up with.....Reliance Controls 31406CRK - Power Transfer Kit for Portable Generator
For years we used to run ext cords all over the house.....not anymore....plus we have our well hooked up......
Last spring we had 6 days without power and other than the noise of the gen in the sideyard we sometimes forgot there was no power outside......
I agree with hiring electrician if you are not elec savy......:thumbsup:
Travelover,
Like this one?
/ Emergency Generator #39
I tried and tried to get my power company to either let me get a Generlink installed or have them purchase and install for me to rent. They wouldn't do it and would not even consider it. Stupid ignorant. Johnson City Power Board. I wanted a sub-panel but the knucklehead who built this place put the main panel in the kitchen. I have it covered but no room to put sub panels at all. I went with a sliding generator plate. I can now plug my generator in outside, slide the plate over, and use existing breakers. I put two watt meters in the top of the panel cover so I can monitor the usage.
I wish I could economically relocate the panel to the basement where it should have been in the first place.
/ Emergency Generator #40
I didn't do anything with a 2nd panel. If you have 2 open adjacent slots in a Square D box, you can get an interlock kit that will tie a 2 pole breaker to your main, requiring 1 to be off for the other to be on. Then you run a heavy wire from this 2 pole breaker to an inlet box, much like the one posted earlier. In the case of a power outage, you plug the extension cord from the genny into the inlet box, start the generator, then flip off the breakers you don't need, and the main breaker, slide up the interlock, and flip on the inlet breaker. I now have the ability to power any outlet or light in my house. Some utilities don't approve of using a breaker like this to be the disconnect, but I also have a hard disconnect on the outside that I can pull to cut my house off of the grid if needed, but the inspector says i'm fine as is. I can't find the kit now, but you used to be able to get them from Lowes for about $30. I think the entire project cost me about $100 including the inlet box off E-bay, the wire and the heavy 2 pole breaker.
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
2024 JCB 35Z (A60462)
Iranch IRGC40 (A60463)
Case Titan 3530 (A61307)
Case Titan 3530...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
2015 John Deere 3038E (A60462)
2015 John Deere...
