Electrical system issue
/ Electrical system issue #1
Hay Dude
Epic Contributor
The Last Red State in the Northeast
Challengers: MT655E, MT555D, MT535B, Massey 7495, Krone 4x4 XC baler, 2-Kubota ZD1211’s, ‘20 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 38K trailer, Deere CX-15, 2 Pottinger Hay mowers, NH wheel rake, Claas 30’ tedder
Massey 7495 Farm tractor
Has 4 way flashers
has turn signal stalk just like a truck
has 7 pin trailer plug
The turn signals over ride the 4 ways - a really nice feature.
a few days ago, I plugged my rear mower into the 7 pin plug and immediately noticed the right side of the mower and tractor signals don’t blink.
If I turn on the 4-ways, only the left side blinks.
If I turn on the left turn signal, it blinks properly.
Whether rear mower is plugged in or not, I only have a left turn signal.
Nothing works on the right side. No turn signal, or nothing when 4-ways are turned on.
Checked all fuses and found nothing
I replaced the flasher relay.
There’s also a left side and right side relay for turn signals. I swapped them and still only have left side signal.
/ Electrical system issue #2
You might try spreading the pins very slightly to tighten the plug connections.
/ Electrical system issue #3
I agree with kirkawilson. It’s most likely a tighten up clean up issue. Anywhere you can sand any spray with contact cleaner try it. It might turn out to be an easy fix if you are one of the lucky pnes
You mean pins on relays plugged into fuse circuit board?
/ Electrical system issue #5
If they all quit then four things have to be eliminated.
1. No 12VDV.
2. No ground.
3 All the bulbs burnt out.
4. The switch itself could have lost power.
Power comes from 1 or more fuses. Is power getting "to" the fuse and "through" the relay contacts?
Ground is common through the chassis (not likely) or individual wires back through a common connection.
Do you have a good ground at the bulbs?
Don't forget to check for voltage at the switch
/ Electrical system issue #6
Are these 1157 incandescent bulbs or LED?
/ Electrical system issue #7
/ Electrical system issue #8
I was referring to the pins on your 7 pin plug. That connection might need some electrical spray cleaner.
/ Electrical system issue #9
Is your Massey a 7 pin round connector?
european 7 round;
our HD 7 pin round;
and the other 7 pins;
All wired differently.
