LD1
Epic Contributor
Lets see what the brilliant minds come up with here.
background....wiring parents new house. This is log-home type construction so wiring is a PITA. We only ran 1 wire to where the ceiling-fan and light will mount in the lifing room. No chance at running another wire to that location.
So the dilema, we have ONE wire from the switchbox to the fan. How to control BOTH the fan and the light with that one wire?
Pretty easy, use a wall mounted remote fixture. BUT, would also like that light to be controlled from a second location (3-way). That way, that light can be controlled from the entrance from the garage as well as the front entrance.
So are there any of them remotes that are able to be used like a 3-way? I havent had any luck. Its not the end of the world if it cannot be controlled from 2 locations, but if it is doable, we want to do it, but just cant find much info on it yet.
I know the wall mounted remotes have a code that gets entered. What would happen if we set two of the codes the same and tried to control the fan/light with two remotes programmed the same? or would they just clash with eachother?
