Electrical question
   / Electrical question #41
   / Electrical question #42
Sorry, again, for the thread hi-jack. Should start a thread but don't really know what to call it. 600 Volt Rotary Phase Converter Grounding Maybe.
Thanks for the input.
   / Electrical question #43
Yes, I apologize as well... I should know better...
   / Electrical question #44
Sounds logical to me.
   / Electrical question #45
Done. New Thread opened.
   / Electrical question #47
Watts is a unit of measurement that in it's simplest form equals Volts x Amps... 2000 watts / 240 volts = 8.33 amps used. 2000 watts/120 volts = 16.67amps.
Less amps = lower electric bill..
My power bill is in kilowatts, not amps. Am I missunderstanding my power bill?
   / Electrical question #48
Your meter voltage is 240 volts whether or not you use 240, or 120 . Kwatts is 1000 voltamps... so using 240 on a pool pump means 1/2 the current. Ohms law states where resistance is constant, voltage and current are inversely proportional. So more voltage = less amps. Less amps = less kilowatts used. Amps are a measurement of electron flow.
Note I avoided the word POWER.. my explanations are bad enough without making it worse trying to equate it with work.., horsepower etc. If someone can explain it better, please do..I was terrible at physics.
   / Electrical question #49
In your previous example the bill would be the same, 2000w powered by 120 or 240 is still 2000w or 2kw.
Difference between watts and va is much more complicated. In reality unless you're talking about a resistive heater out is likely your scenario would be same va but lower watts.
   / Electrical question #50
I was trying to keep away from anything with impedence, purely resistive. Now that I think about it, about the only thing that really applies is a water heater.
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2005 CATERPILLAR 740 - 6X6 OFF ROAD WATER TRUCK (A52706)
2005 CATERPILLAR...
2017 Ford Escape AWD SUV (A55758)
2017 Ford Escape...
2013 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2013 Ford F-550...
