Electrical question - recessed ceiling lights
/ Electrical question - recessed ceiling lights #1
ejb
Platinum Member
Hi guys....
Quick electrical question: I need to install at least 4, and maybe 8 recessed ceiling "cans" in my family room to bring in some much needed light...its in the cieling of the 1 story section of my house, which is of course insulated with fiberglass...so I was looking at units at HD that are rated for use in direct contact with insulation, at picked out the right sized bulbs so as not to overheat...but then a tiny little mention in the install directions said I should make sure the supply line (wire) was rated for at least 90 degrees celcius...I couldn't find anything on my regular 14/2 or 12/2 roll of wires that indicated what temp it was rated for??? What kind of wire do I need to ensure that it will withstand 90 degress celcius?
/ Electrical question - recessed ceiling lights #2
Good question, as I am diving into some old ceiling lights that have been 'buried' in the ceiling or 37 years. They show some signs of 'heating' the insulation around the wires.
Here is a site I found wire cable , that has the information you need, I think.
/ Electrical question - recessed ceiling lights #3
Not sure about 14/2 and 12/2 but THHN is rated for 90c.
/ Electrical question - recessed ceiling lights #4
Maybe this will help
Look for the letters NMB on the jacket of the wire. The NM means nonmetallic sheath cable (Romex) and the B suffix means that the cable's conductors are rated for a maximum operating temperature of 90°C 194°F. We can assume that wiring made prior to 1984, without the B suffix, is rated at 60°C 140°F. This is the type of wiring found in most older homes that were built before 1982.
Yes, that does help..thank you. It looks NM-B is what I have anyway, and should work just fine. Thanks guys for the quick help.
/ Electrical question - recessed ceiling lights #6
Isn't this place amazing? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2020 WESTERN STAR  4900 TRI AXLE (A65643)
2020 WESTERN STAR...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
Homemade Utility Trailer (A62613)
Homemade Utility...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2008 Case IH JX80 Loader Tractor (A66285)
2008 Case IH JX80...
