Electrical Problem with Kubota L3130
   / Electrical Problem with Kubota L3130 #11
Generally "system" power is taken off directly at battery terminal (second wire to/at main cable to starter) or a double up connection on terminal on starter solenoid.... Anyway whatever point the power is tapped off of it usually goes to a "master" fuse or fusible link on newer tractors that powers up everything on tractor....
   / Electrical Problem with Kubota L3130 #12
This morning I had the same problem with the same model tractor -- checked battery and fuses -- still nothing -- totally dead. I came in for lunch and found your post and the problem was solved by just cleaning the one electrical connection.
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2012 PETERBILT 386 (A50854)
2012 PETERBILT 386...
2025 LandHonor LHR-EW20000 20,000lb Electric Cable Winch (A49461)
2025 LandHonor...
2013 MACK CXU (A50854)
2016 John Deere 35G Mini Excavator (A49461)
2016 John Deere...
