Electrical Problem - JD 455
/ Electrical Problem - JD 455 #11
You can sight check it or jiggle it on the back if you can reach it while turning the key. If it responds at all; just stop and go get a new switch. My 314 and 317 won't run without a good switch, so it isn't just for starts.
/ Electrical Problem - JD 455 #12
If your 455 is like my 345, there is an electronic printed circuit board that controls all the electrical functions on the tractor. When it fails and mine has failed twice, nothing electrical works. However, the second time it failed, I discovered that I could start the engine by jumping across the starter solenoid. Try jumping across the starter solenoid to start the engine so you can drive it to the shop.
The replacement circuit board from JD costs about $130 and requires un-soldering/soldering several electrical connections.
Bill
2018 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A59230)
2018 Peterbilt 567...
PREVIEW DATES AND TIMES (A61165)
PREVIEW DATES AND...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2007 JLG 600S Manlift (A61166)
2007 JLG 600S...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
