electrical/ pressure switch question
   / electrical/ pressure switch question #42
you've probably aready solved this: but here goes anyway: it could be wired like a oven is: one side of the 220V being there all the time, and the pump only runs, when the other leg is applied: then you would have 120V at the breaker box at all times: or like some have said, move your pressure tank closer to the pump: get one of the really small pressure tanks, put the switch on it, and install it close to the pump: OR put in a 120V pump: i have installed several 120V pumps and they last for years and years: a lot of folk will say a 220V pump uses less current, which is true, but if your wire is large enough to handle whatever the current is on a 120V pump, who cares!!!
heehaw
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
UNUSED Brown Metal Roof Panels (A50860)
UNUSED Brown Metal...
2018 Infiniti Q50 AWD Sedan (A48082)
2018 Infiniti Q50...
2005 Caterpillar 262B Rubber Tire Skid Steer (A50860)
2005 Caterpillar...
Coleman BT200X Mini Bike (A50860)
Coleman BT200X...
2018 John Deere 460E Articulated Dump Truck (A51039)
2018 John Deere...
