Electrical Issue
/ Electrical Issue #1
WCS755
John Deere 755
Hi, I have a John Deere 755 compact tractor. Since early fall I have had an electrical issue. The tractor will stall during use. It restarts but stalls immediately. I discovered that the 10amp fuse which corresponds to the starter, panel, ect. was blown. Replacing it 2 or 3 times has worked. Now as soon as I put a new fuse in and start the tractor, it immediately blows the fuse. Does anyone have any ideas where to look? I appreciate your consideration.
/ Electrical Issue #2
trace the wires from the fuse you have a short
willy
/ Electrical Issue
Thanks Willy, that was my intention. Today I followed the wire from ignition to the fuse block and from fuses to alternator. I couldn't find an obvious issue but in moving the connections and harnesses around I got it to start and back to the barn for now.
/ Electrical Issue #4
Do you have a wiring diagram ? That will go a long way to help you find the issue.
Could mice have chewed thru the insulation on some wires ?
Richard
/ Electrical Issue #5
Possibly a bad sensor, most sensors on certain JD tractors are tied to the start/ignition fuse.
/ Electrical Issue #6
If moving the harness around sporadically fixes the issue, you almost definitely have either an abraded wire or a loose connection. It's a hassle but just following the wires from start to finish will usually reveal the issue.
/ Electrical Issue #7
Ok now if it stalls during use it has nothing to do with the starting circuit. That fuse goes to something that’s energized while it running. And it could be many things So the isolation process begins!
/ Electrical Issue #8
You need to trace the relevant wires back and unwrap the wiring bundle to see what you're looking at. It's a PITA but needs to be done
/ Electrical Issue #9
sounds like the fuel solenoid is dropping out or loosing power, below are what is involved in keeping the fuel open.
I have a PDF of the technical manual for your 755, all the electrical diagrams and testing are in it, check your private messages for contact info if you want it
Joe
/ Electrical Issue #10
Joe
Joe that is awsome. He will enjoy that
/ Electrical Issue #11
By moving the wires your tractor started try just moving one wire
at a time and then try to start this way you just might find the wire
that's causing the problem could be a dirty connection
willy
/ Electrical Issue #12
No, if it's blowing a fuse, it's not a bad connection, dirty connection or loose connection. Those issues don't blow fushes.
It is a short circuit to ground or an overloaded (not likely) circuit.
Try replacing the fuse with a 12 volt headlamp. If the headlamp glows brightly, the circuit has a dead short (circuit to ground)or a pretty heavy load.
If, when you unhook components or wiggle various wires, the headlight goes dim or put completely, you are zeroing in on the fault.
/ Electrical Issue #13
That is a great suggestion and a great way to trouble shoot.
/ Electrical Issue #14
I would think that a short is a bad connection and by moving
the wires one at a time just might find the wire that has a short
because the wire could have a bare spot and moving it could
make contact
willy
/ Electrical Issue
Hi Richard, I do have the diagram. I followed the circuit but found no apparent damage. I had moved the wires around searching and when I tried a new fuse (using a 15 amp instead of a 10) it ran.?
Richard
/ Electrical Issue
make contact
willy
/ Electrical Issue
I'm almost positive there is a bad wire or a ground issue. While looking for it and moving the wires and harness around I got it to start again with a new fuse. I had to put in a 15 v instead of a 10a, until I get to NAPA. Makes me wonder about a voltage spike from the alternator too.
/ Electrical Issue
Yes. I'm afraid I have some hours with a bright light and a multi meter in my very near future.
/ Electrical Issue
Joe, thanks so much! I managed to find a free PDF online. I will look at the selenoid. It was replaced this summer. Every time I blow a fuse it is during heavy vibration, ie; moving, plowing snow, or hitting a bump too quickly. That's why I was thinking a wire or connection.
/ Electrical Issue
Joe
Joe, this old tractor has some character. It can be started in gear. I am definitely going to check the selenoid though.
Hilti TE 2000-AVR Electric Jack Hammer (A60352)
Hilti TE 2000-AVR...
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
BOX BLADE (A58214)
BOX BLADE (A58214)
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
Bobcat A770 (A60462)
Electric Golf Cart (A56859)
Electric Golf Cart...
