Electrical connections
/ Electrical connections #1
texoak51
owasso,ok
kubota m6800dt
Wanting to add Driving lights on the rops of my m6800. The wiring harness at the rear that leads to my flashers and tail lights have a large and small connector of some type coming off the harness on each side that are just hanging there taped to the harness. Are these for additional lighting and if so what is the max. wattage I can attach? Sorry but I am totally ignorant about electrical. Thanks
/ Electrical connections #2
If you are "totally ignorant about electrical", I would get a service manual for tractor and also use Google to find videos or tutorials on doing this. I was somewhat ignorant and before I went tearing into my motorcycle electrical, that is what I did. It doesn't take much to futz something up and it can be a real bear to trace it down.
/ Electrical connections #3
If it's like my B-series, there are the work light leads in the right rear fender, which are switched on/off with the key (I have no extra wiring in the left fender). They should matchup with a corresponding slot in the fuse box. Mine had a 20A fuse, which would tend to indicate that the wiring can support at least 20A. Of course, alternator capacity and other loads should factor in as well. I used LED lights which only draw about 1.5A each, and they are insanely bright.
Do a search for more information -- lots of threads about putting work lights on Kubotas.
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
2004 IC Corporation 3000IC School Bus (A64194)
2004 IC...
2018 CASE TV380 SKID STEER (A65053)
2018 CASE TV380...
2006 Honda Accord Sedan (A64557)
2006 Honda Accord...
2009 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A64556)
2009 Chevrolet...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
