Electric Transmission?
/ Electric Transmission? #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
/ Electric Transmission? #2
Knowing how expensive big Deeres are to maintain, I bet it will be as well and of course i keeping with JD's no right to repair attitude, probably won't be any repair manuals printed except for dealers.
I found interesting the 100KW built in generator part of the system. I am curious, however, at what voltage and AC or DC? The Deere PTO driven generator that is used to power their electric drive planter meters is some odd like 56 volts.
Interesting is that they are promoting the 100KW to power an auxiliary device such as a trailer behind the tractor. Makes me wonder what "they" have up their sleeve and what the future holds.
Edit: Seems like the system would have to be fairly high voltage otherwise taking humongous size cables to transmit 100KW to an external device?
Lugged tires on tillage implements driven by the 100KW generator? Would require less tractor weight resulting in less compaction by utilizing weight of the implement to supplement the tractive force? I don't know, just kind of interesting I guess.
/ Electric Transmission? #5
1st step in direction of Battery powered John Deere's. After all there are diesel generator Locomotives in use for a gazillion years now. Why not a tractor ?
/ Electric Transmission? #6
The Deere eAutoPowr transmission utilizes two high-power electric machines, instead of the conventional hydrostatic unit, to achieve the required gear ratio. One electric machine is coupled to the engine and the other is coupled to the summing planetaries to deliver infinitely-adjustable wheel speeds.
Toyota invented this for the Prius 25 years ago, and most other hybrid cars have copied it on some level. If you use 2 motors as inputs to a planetary gearset (which usually have 1 input, 1 'held/braked' element and 1 output) and vary the speeds of those two inputs you get an infinitely variable gear ratio from a very small number of parts.
It's brilliant. It changed the world! But it's no longer new. Maybe new to tractors. :)
The 1997 Prius:
A demo of the Prius transmission.
The Caterpillar D7E is a "diesel generator locomotive".
Agricultural implements with powered axles are already successfully used in Europe to help push the tractor from behind while working in the field. "EVT technology offboards electricity from the tractor to provide added power to the implement and can reduce wheel slip, improve up-hill performance, and enables the tractor to pull wide implements without the need for extra ballast or a larger tractor," Jardon said.
The above is an excerpt from this:
Feel like I'm talking to myself here but that's okay as long as I don't start answering myself! :)
/ Electric Transmission? #10
I have a PTO-driven 3pt trencher I was using today. Only the chain bar is pto-driven, but it also requires hydraulic hookups! It has a hydraulic motor and a driven wheel axle. The reason is that you leave your tractor in neutral and use the hydraulically driven axle to give you a finely-variable low-low-low gear creep speed so your tractor only moves as fast as it trenches. You can set it to move one inch per minute if you want to. So you're no longer really tied to 'gears'.
With electric drive you can also do the same torque in forward and reverse so any time you have a modern electric drive you also have electric braking, so that's nice.
Farmall M had an option which included a generator to power a motor on the hay baler back in the early fifties.
/ Electric Transmission? #12
I have seen a few of the generators on M's and it was also offered on the 300 and 400 Farmalls, it mounted to the belt drive.
I had not heard of the electric powered baler. Around here the generator option was sold as a power option for power outages.
It never sold very good as it was much more expensive then a pto generator and you could drive a 15 to 20 Kw generator with the M or 400.
It was also clumsy and hard to mount and remove as it's quite heavy.
/ Electric Transmission? #13
Still amazes me how much Farmall was ahead of their time, or at least explored new ideas and brought them to market.
Oliver was also an amazing company. Read that John Deere stole some of Oliver’s ideas on planters.
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
Club Car Emergency Cart (A64557)
Club Car Emergency...
2014 Grand Caravan (A62679)
2014 Grand Caravan...
Used Landpride GR1525 Stump Grinder
Used Landpride...
1999 Sterling Dump Truck (A66285)
1999 Sterling Dump...
2010 Transcraft 35ft. Tri-Axle Aluminum End Dump Trailer (A64556)
2010 Transcraft...
