Electric Seed Spreader
/ Electric Seed Spreader #1
dallasfan458
Chester County, PA
John Deere 955
I have a walk behind wheel powered seed spreader that is broken, the spreader plate does not turn with the wheels anymore so I want to add an electric motor to it and mount it to my mower or larger tractor. Does anyone have any idea what kind of motor I should use? (Size, torque, RPM, etc.) Any input would be appreciated, thanks.
/ Electric Seed Spreader #3
Wonder if you could use a starter from a Briggs or similar motor? Might need to figure out a way to control the speed. Lots of them available used, and at considerably lower price.
Sounds like a good idea, only thing is I have no idea what rpm I should be using. I dont want something throwing seed 60 feet away but I dont want something where the seed just drops right off.
/ Electric Seed Spreader #5
Bad idea. Starters are high output motors designed for very brief intermittent usage. You can burn em up in minutes if you keep cranking when trying to start an engine that doesn't want to fire. They also suck major juice.
/ Electric Seed Spreader #6
Check and see what The Surplus Center has. I bought a 12 volt sealed motor for one a few years ago and it works great. Be sure to check the motor speed as they are made in many different RPMS. I think mine turns at 600 RPM's. Another possibily would be a motor off one of the spincast deer feeders
/ Electric Seed Spreader #7
try a car (heater-AC) blower fan motor, if needed put some resistors on the line to slow it down, if you go to a junk yard one could most like get the blower speed controller as well as a blower motor, then one would have three speeds or so, and the cost would be reasonable,
some experimentation on the impeller would or could change the throw of the impeller,
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
2019 Chevrolet Express Box Van, VIN # 1HA3GTCG9KN007839 (A65563)
2019 Chevrolet...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2024 Polaris Sportsman 570 AWD ATV (A64557)
2024 Polaris...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
