Electric Hot Water Heaters
/ Electric Hot Water Heaters #21
Have you given any thought to an On Demand system? It may save you money if you don't use the hot wateer all the time.
/ Electric Hot Water Heaters #22
I've heard that only the gas on demands are worth getting, and I think the OP said he was all electric.
Chuck
/ Electric Hot Water Heaters #23
Electric on demand for all practical purposes are only good as small point of use units. So you could have one for the kitchen, one for each bathroom with possibly a separate one for the shower, one for the laundry, etc. The whole house electric ones seem to be prone to problems.
Ken
Yes, I'm the original poster, and we don't have gas, and don't want to get involved with a propane tank. We need to go with an electric hot water heater. I've also heard that on demand is not efficient in electric.
/ Electric Hot Water Heaters #25
We are all electric as well, I looked into the electric on demand systems, you can find ones that work but you need a lot of amps (50-120) to get one that works well. I ended up replacing ours with a Marathon high efficency heater- I think it has a lifetime no leak (it's plastic). Our electric company gave us a $200 rebate and sold them directly. Easy one person install due to how light it is- been happy with it so far.
Marathon Water Heaters
/ Electric Hot Water Heaters #26
I have one of these GE hybrid electric heaters.Hot Water Heater, Heat Pump Water Heater, Water Heater Electric | GE Appliances
Its pretty quiet, it costs more upfront but you can get federal and power company rebates, making it cost the same as a regular electric water heater.
I got rid of propane at my house, and with the need for a backup generator sometimes, you can force this water heater to be in 'power save mode', which uses about 1000 watts (vs 4500) of power, so that you don't have to have a huge generator. Or just leave it in the mixed mode, it will use the low power mode unless there is a big demand for water.
/ Electric Hot Water Heaters #27
OK, what am I missing on that GE hybrid? It is using the house as the source of warm air. So in the winter, your heating system is supplying the heat. Granted, in the summer, it is helping to cool your house. Where i live, heating is a bigger issue but further South it might make sense.
Ken
/ Electric Hot Water Heaters #28
With the hybrid, it will cool the room that is located in. But if this is the garage/attic, that won't be a problem.
If your garage is slightly warm, it will still be able to extract heat from the air, just as your house heat pump does.
I have mine vented to the outside and draw air from the outside, I will alter that for the Summer to help with the A/C mode of my heat pump system. I haven't got around to modifying my utility room yet since I had the propane equipment taken out.
It will also take moisture out of the air, as its a mini-heat pump.
In my house for heat I use a heat pump, so I would still be saving money even if the water heater was in the house.
/ Electric Hot Water Heaters #29
Just replaced the 20 year old, original propane heater at our place. It was past time. The high price of the new propane WH drove us to examine the electrics. The much lower price, even with slightly higher prices for electric over propane, made the break even point 8 years. It was a no brainer.
For around $280, brand new, GE electric. Lowe's I believe. No complaints, no regrets whatsoever. Love it. Yes, I also checked the thermostats to make sure the lower matched the upper. I set them down just a tweak from the factory presets.
/ Electric Hot Water Heaters #30
Insulating any type of tank (not on-demand) is important. You want to hang on to the money spent to heat the water is the way I think of it. If your heater is cycling when you haven't used much hot water, that's a sign of heat loss due to lack of insulation.
Dave.
/ Electric Hot Water Heaters #31
I had the marathon125 gallon one installed,use off peak power program and my monthly bill is about 8-9 dollars.Its plastic and super foam insulated,lifetime warranty but about 800 to buy.I,m very happy with it.:thumbsup:
/ Electric Hot Water Heaters #32
Just curious.. why are you heating your hot water? ;-) LOL
/ Electric Hot Water Heaters #33
It must be just a saying.:confused2: I always get the calls .. My HOT water heater isn't working. Instead of saying,,,my water heater isn't heating the water;)
/ Electric Hot Water Heaters #34
My hot water heater mostly heats hot water. Hot being defined as anything above incoming water. It also heats cold water. So I guess it's a mostly hot water heater.:)
UNUSED FUTURE ELECTRIC WET POLISHER (A60430)
UNUSED FUTURE...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
2018 Deere 323E (A53317)
2018 Deere 323E...
2025 JMR Tree Boom Mini Skid Steer Attachment (A59228)
2025 JMR Tree Boom...
2007 JOHN DEERE 605C CRAWLER LOADER (A60429)
2007 JOHN DEERE...
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
