ELECTRIC FENCE LIGHTNING DIVERTER THOUGHTS ?
/ ELECTRIC FENCE LIGHTNING DIVERTER THOUGHTS ? #1
bullbreaker
Elite Member
SW FLA
D Ranchers daughter'$
Howdy too All !
Maybe its just me but I don't think so . Of the countless TBN threads /posts I have read throughout the years , it seems like when it comes to electric fence threads rarely do you hear someone mention a lightning diverter installed inline to protect especially their high $ chargers .
Whenever I have ran and installed a permanent electric fence charger I have always used in series with it a Kencove L diverter . Like this one : Lightning Diverter Of course there are other types /models manufacturers that build them of different designs for the public . I'am in sw Fla what I would consider heavy lightning country . From the ones I have installed for me and others it seems like we have never lost any chargers to lightning . This just might be coincidence !
Any of you's out there also running lightning diverters on your high dollar units ? If so what brand ? Any of you's out there ever lost a charger fried by lightning with a lightning diverter correctly installed inline ?
Anybody out there think or know for sure if lightning diverters are "SNAKE OIL" for sales and profit ?
Electric Fence Lightning Diverter 11 - YouTube
How to protect your energizer from lightning | Patriot - YouTube
Thanks for any replies in advance !!! (sorry for all capital letters on thread heading couldnt fiqure out how to correct ).....
/ ELECTRIC FENCE LIGHTNING DIVERTER THOUGHTS ? #2
/ ELECTRIC FENCE LIGHTNING DIVERTER THOUGHTS ? #3
Long ago I had a small - low dollar - electric fencer. About 450 feet of electric fence. Only used this arrangement for two years. Manufacturer recommended one ground rod. So - that's what I did.
However - if lightning would have ever hit the fence or fencer unit - I would have fully expected to see a blinding flash.
I really would not hold out much hope if lightning made a direct hit on the wire or the fencer unit.
I've seen what lightning does to a power transformer on top of a power pole. It ain't pretty.........
kenmac thanks for pointing out and reminding me some manufacturers claim some internal protection in there units . No doubt "Cyclops" makes some bad arse units . Just like Stafix / Gallagher(Kiwi) /and a few others . Stafix SE36R Energizer (Remote Included)
– Powerflex
Agreed , yeah I hear Ya ! Seen it also the "oil" ? or whatever is in them transfomers at least back then was on fire before it hit the ground . Started good size fire .
/ ELECTRIC FENCE LIGHTNING DIVERTER THOUGHTS ? #6
think about it for a bit, lighting will jump thousands of feet through the sky, and some little wire an 3/4' to 1 inch away from the fence sill drain it off and not bother the fencer, I don't think so,
It may help for a near miss, or if the air gets charged, but a direct hit, it crispy critters,
/ ELECTRIC FENCE LIGHTNING DIVERTER THOUGHTS ? #7
I put one in on my fence. My thought was that the fence covers a lot of area and odds are decent that if lightning hits anywhere near the fence, it's going to cause problems. I've had clients that had all of their electronics fried from lightning strikes 100 feet away. If I never need it, I'm not too worried about what it cost.
I have the one in your first video.
/ ELECTRIC FENCE LIGHTNING DIVERTER THOUGHTS ? #8
I was sitting in the house during a lightening storm about 5 yrs ago.
I watched as lightening hit a tree. It ran down the tree. Jumped off a limb and went through the roof of a small utility shed.
It then traveled through the electrical wire in that building, missed the ground rod at that bldg. traveled through electrical wire all the way up to my garage, went through that electrical panel missed a ground rod there. Then, traveled to my home where into that electrical panel, burn up my security system then left through that ground at the house.
If lightening hits something electrical, I'm not so sure anything will save it
/ ELECTRIC FENCE LIGHTNING DIVERTER THOUGHTS ? #9
– Powerflex
Reason I went with this unit is, it's made by a guy that lives about 30 minutes away from where I live. If something happens to it I can drop it off at his shop for any repairs
/ ELECTRIC FENCE LIGHTNING DIVERTER THOUGHTS ? #10
"Positive lightning strikes tend to be much more intense than their negative counterparts. An average bolt of negative lightning carries an electric current of 30,000 amperes (30 kA), and transfers 15 coulombs of electric charge and 500 megajoules of energy. Large bolts of negative lightning can carry up to 120 kA and 350 coulombs.[40] The average positive ground flash has roughly double the peak current of a typical negative flash, and can produce peak currents up to 400,000 amperes (400 kA) and charges of several hundred coulombs.[41][42] Furthermore, positive ground flashes with high peak currents are commonly followed by long continuing currents, a correlation not seen in negative ground flashes.[43]
As a result of their greater power, as well as lack of warning, positive lightning strikes are considerably more dangerous. Due to the aforementioned tendency for positive ground flashes to produce both high peak currents and long continuing current, they are capable of heating surfaces to much higher levels which increases the likelihood of a fire being ignited." Lightning - Wikipedia SO, Lightning protection needs to be REALLY heavy duty!.. on the order of at least 400,000 amps.. for a direct strike!..
Since I started this thread I didnt want to start another just to show this : https://www.amazon.com/gp/customer-...f=cm_cr_arp_d_rvw_ttl?ie=UTF8&ASIN=B0079GH4ZW .Came across this ,read the first review titled "Heifers ridin' lightin' / look at pic . Cant really believe it ? What you all think ? Animal hit by lightning ? Bad weak heart ? Got zapped standing in water ? Can't believe reviewer even posted that ?
Hey there again Eddie ! Hope you see this . Is that your review aways down from the zapped heifer review ? The guys got the same name . If so are you still running this Zareba 50 miler since 2015 ? https://www.amazon.com/Zareba-EAC50...0079GH4ZW/ref=cm_cr_arp_d_product_top?ie=UTF8
Just wondering ?
/ ELECTRIC FENCE LIGHTNING DIVERTER THOUGHTS ? #13
Just wondering ?
Yes, that's my review and what I'm using. It's worked flawlessly since installing it. Maybe too good!!! About a year ago I was walking by the fence with a T-post and wasn't paying attention to where the back end of the T-post was. As I went through the gate, I turned and touched the hot wire with the T-post. The shock was overwhelming. The T-post fell to the ground because I lost control of my hands. I popped just about every joint in my back and it felt like something popped in the back of my brain. I've touched hot 110 wires before and this was a lot worse then that!!! Then two weeks ago I was carrying a box fan as I went through the gate and did the exact same thing again. I wasn't paying attention to where the fan was and when it touched the hot wire, I had the exact same reaction as the first time. Only difference is that I really felt stupid for doing it again. Since then I've been planning on wrapping that wire with something. Probably slice up a piece of PEX and slip it over the wire. I really need to do that right away.
2006 International 4200 2,000 Gallon Water Truck (A61573)
2006 International...
2007 John Deere 1790 Planter (A63111)
2007 John Deere...
2011 Honda Civic Coupe (A61574)
2011 Honda Civic...
2016 Cadillac XTS Sedan (A61574)
2016 Cadillac XTS...
JOHN DEERE 1700 - 8R30" VACUUM PLANTERS (A63291)
JOHN DEERE 1700 -...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
