EGT, Temp, Fuel Guages
/ EGT, Temp, Fuel Guages #1
Anonymous Poster
Epic Contributor
I've searched and really haven't found anything on TBN.
Has anyone added gauges to there tractor to monitor it better.
EGT, Trans Temp, Engine Temp, or Fuel Pressure?
Also, those with turbos, Boost gauge?
I have no plans to mod or bomb the tractor,
but I am thinking about adding a EGT gauge come Spring.
Cummins gauges on xmas wish list.... /w3tcompact/icons/wink.gif
John
/ EGT, Temp, Fuel Guages #2
You'll find that your local Cat dealer will have all kinds of engine gauges that can handle weather. Also, truck dealers (Peterbilt, Kenworth, etc.) might have some, but they are probably more designed for in-cab installations.
Why do you want to monitor exhaust temp? It seems that only turbo engines tend to have pyrometers.
Just curious.
Cool factor? /w3tcompact/icons/smile.gif
But seeing the actual #'s would be interesting, especially while brush hogging or finish mowing. I know my shoes and front shins get awful toasty while mowing for 4 hrs in 95 deg weather from the heat blowing back from the motor. Also, let me know how the hydro is running to. I seems to run pretty warm when the pto is going full steam.
More curiosity than anything, I was hoping someone may have been-there-done that. ;)
/ EGT, Temp, Fuel Guages #4
There's really no reason to put them on a compact tractor or subcompact tractor. These tractors don't make enough horsepower to hurt themselves. They also have governors on them to prevent over revving.
If you're talking about the big tractors then yes I have those gauges on my big tractors.
Why would you want to add egt to your tractor if you don't have a turbo?
/ EGT, Temp, Fuel Guages #5
I'll second the;
w/o turbo u don't make enough heat to
worry about.
Make note to self - Get turbo for tractor /w3tcompact/icons/grin.gif
/ EGT, Temp, Fuel Guages #7
Or atleast alcohol injection (NOS might help),
for the tractor NOT the operator :)
/ EGT, Temp, Fuel Guages #8
Yeah I like gauges.
I like to see what is going on.
Keeps one busy !!
Cheers
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
Compressor (A55973)
Compressor (A55973)
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59905)
2018 FREIGHTLINER...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
Zero Turn Mower (A59231)
Zero Turn Mower...
