echo SRM 210 string weedeater
/ echo SRM 210 string weedeater #1
lazymjs
Jacksonville AR
Gravely
I have a echo SRM 210 weedeater that starts but will not run. I have performed the following: Fueled with commercial 50;1, Replaced the air cleaner, Replaced the Spark plug, carburator, muffler and all fuel lines. checked engine port for carbon buildup. No improvement, am at a loss for what else to check or due. Recommendations please.
/ echo SRM 210 string weedeater #2
Checked for junk in the tank?
Bruce
Yes, flushed several times with commercial 50:1
/ echo SRM 210 string weedeater #4
OFF-ON switch or wiring intermittent short?
Spark at the plug electrodes?
Bruce
I checked spark..appears to be adequate. Did not think of intermittent switch wire, will try to check on that tomorrow. Appreciate it.
More I think about the switch, it starts every time, would that happen with an intermittent wire?
/ echo SRM 210 string weedeater #8
Natural position may be OK but running vibration may make it touch something. Just another thing to check.
Does it start, then die immediately, or will it run a bit with choke on, then die with choke off?
With fuel line off carb, will fuel flow freely? Thinking of a plugged hose nipple on tank.
Bruce
/ echo SRM 210 string weedeater #9
Reversed fuel lines into carb when re assembled ?
Reversed fuel lines could be a possibility, when I replaced carburator I had no picture showing me how they should be connected. I have the white round tube in the housing cavity for it on the right, then the black tube to the center and the orange tube on the left. I thought that was how they came off (to the best of my 80 year old memory);
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
2016 PITTS LB35 - 33CS LOWBOY TRAILER (A64277)
2016 PITTS LB35 -...
ATS ATS-PC90 Heavy Duty Plate Compactor (A62679)
ATS ATS-PC90 Heavy...
2022 EZ-GO ELITE...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
New 11'x19' Steel Carport with 10' open sidewalls  (A62679)
New 11'x19' Steel...
