Echo 590 or the X Series?
   / Echo 590 or the X Series? #111
I've barely used it, but so far, I'm very impressed. I think I ran it for half an hour on Saturday, and maybe a little over an hour on Sunday. I'm surprised at how light it is and how easy it is to handle. Starting it is very easy, which is a big deal for me. I hate it when I can't get a saw to start!!!! I think the canned fuel makes a big difference too, so it might be the combination of having a new saw, and better fuel. I might like some of my other chainsaws better with this fuel!!!!
I tried the pull handle to open the fuel and oil caps and it works great. Thanks for that tip!!!
It's probably going to rain, or be muddy this weekend, so I'm doubt that I'll use it. I have 5 nice oaks on the ground that I dug out with my backhoe. I need to cut the root balls off of them and limb them so I can carry the logs to my splitting area with my grapple. If it's dry enough, I'm looking forward to seeing how the saw performs out in the field, on those trees.
The needle greaser for the end of the bar should be here tomorrow. I'm excited to see what it does. I've never greased a bar before.
For $419, I think I got a great deal.
I think you did as well. Keep that sprocket grease (I grease mine after every use, when I take a compressed air gun and blow out the accumulated chips and dust from the saw before I put it away. For some reason all my saws run better on canned fuel, especially the Red Armor 50-1. If I was using multiple saws everyday then Maybe I'd go with non-e gas and add bottled oil, but I'm not so the additional cost isn't a factor for me. Interestingly, I took some canned fuel and put in my 4 stroke pressure washer because I was out of regular e-gas and it would not run in it. had to go to the filling station and buy some regular weasel pee and add that to get it to run. Very strange. Echo's are hard to beat for the price and quality saws as well.
   / Echo 590 or the X Series? #112
There will be debris in the grease hole, which you don't want to push thru the bearing if you can avoid it. The plastic toothpick on a Swiss army knife I had mentioned earlier works great, but any sharp tool does the job. Then it's just one shot on each side. If you have the chain off, you'll see the fresh grease press out thru the sprocket slot, but there's no need to remove the chain for this.
I grease mine once per day. I go thru two chains in a day of cutting, so it's basically every second chain swap. Be sure to flip your bar with each chain swap, or after each day of cutting if you sharpen on the saw, to maintain even wear. If you're new, wearing out a bar sounds far-fetched, but a few years from now you'll look back and wish you'd done it.
   / Echo 590 or the X Series? #113
I bought a can of Husqvarna premixed fuel because I was walking down the isle in Lowes and saw it, so I bought it. It has an octane rating of 95. I didn't compare the other brands to see what their octane rating was, but I did look at the pump that sells Ethanol free gasoline. It's 91 octane. The Supreme which is on the same hose as the 87 and 89 octane fuel has Ethanol. If I buy the Ethanol free gas, which has it's own hose, it's a lot less octane then the canned stuff, but it's only $3.50 a gallon plus the oil, compared to $30 for the Husqvarna fuel. Is the higher octane rating noticeable or needed? I'm committed to never using fuel with Ethanol in this saw, I'm just not sure if $30 a gallon for gas is being smart or wasteful?
IMO, you're wasting your money if you can easily get ethanol free gas and good oil. Your saw's manual likely has a minimum octane and you'll be hard pressed to find e free stuff in the Lower 48 that doesn't meet whatever that is. Here in NH it's mostly 91ish and I can get it almost anywhere near me.
For good oil, look for the JASO FD rating. Examples being Echo Red Armor, Husky XP+, and I'm about to dive into some VP Racing 2 stroke oil as it is FD rated but cheaper. Plenty others out there.
That's not to say there aren't cases for dudes to buy the pre mix. If it makes sense for your use case, rock on. You likely already know this, but you should tune your saw when you make significant fuel/oil changes. I'm too lazy for that which is why I'm all in on Husky autotune saws.
   / Echo 590 or the X Series? #114
Don’t grease the bar tip you will take out a bar tip that way faster than just about anything. Those greasers are for doing your clutch bearing through the crankshaft if there’s a hole. The only time to grease a tip is when it’s brand new otherwise leave it alone you’ll save yourself a few dollars and some time.
   / Echo 590 or the X Series? #115
I’ve always heard you should always grease it or never grease it. The logic being that grease seals it and stops oil from getting in. I never grease mine and I’ve never burned up a tip so I don’t see any reason to fix something that’s not broken. I put permanently sealed bearings in my lawnmower and never grease them either.
   / Echo 590 or the X Series? #116
One thing to think about is if you’re cutting wood there’s something that will be in or around that hole so why push anything in it unless you can completely flush that bearing out.
   / Echo 590 or the X Series? #117
I just flip my bars, thats about it.
   / Echo 590 or the X Series? #118
Where do you come up with such lore? It's not correct.
Straight from Husqvarna: "It is recommended that you grease the bearing in the tip of the bar each time you refuel." Husqvarna FAQ : Product support - How often should I lubricate the sprocket in the tip of my bar?
The Oregon site contains the same advice. The only exception is Stihl, who went to non-greaseable bearings 10-15 years ago.
I put a lot of miles on my saws, probably more than any non-pro on this forum, and I've always greased my sprocket tips on bars where a grease hole is provided. I've worn out a few bars, and never had a sprocket bearing failure on any bar I've greased. In fact, the only sprocket nose failure I've ever had was on a non-greaseable bar.
I own both, and I prefer the greaseable style. Some of my saws came with Still Rollomatic ES bars, which are non-greaseable, but I replace them with greaseable sprocket nose bars (Total Tsumura or Carlson) when I have the opportunity or need for a new bar.
By your logic, why would they provide a grease hole, if the bar only ever required grease prior to first use? They'd just pre-grease a sealed bearing and ditch the grease hole (like Stihl did), if that were true.
   / Echo 590 or the X Series? #119
Where did I get that from? Many years of running both hand saws as well as mechanical cutting systems from 3/4” to 404” and doing testing for chain/bar manufactures. When speaking to their engineers they say exactly that only grease when first installing by greasing well in service you are more likely to grit up the bearing. Most or the mechanical systems have gotten rid of the grease holes in the tips for that exact reason.
   / Echo 590 or the X Series? #120
Exactly. I greased my bars regularly 20+ years ago. Heard the argument about "always grease or never grease it". So when I replaced a bar, I never greased it. That was about 17 or 18 years ago. I've never greased a bar tip since. I've blown out one bearing in a bar tip since then, and it was in a bar that got severely pinched.
2013 Vermeer V800G T/A Towable Vacuum Trailer (A56857)
2013 Vermeer V800G...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A58018)
2014 PETERBILT 384...
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A56436)
Michelin CARGOXBIB...
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
