BravoXray
Elite Member
- Joined
- Dec 17, 2019
- Messages
- 3,424
- Location
- Nothern Indiana
- Tractor
- Kubota BX2230, John Deere 430 Diesel
One thing Mercedes-Benz does especially well is their dip stick tube run to the bottom of the crankcase pan. Next time try making a fitting to go over the dipstick tube rather than push a tube down inside. Suck all you can out my way, then put your tube down the way you have done in the past. I don't think you will get any more out.I am 80, so crawling under is far from easy anymore.
I have used this exact same E-bay pump for several years now.
My MB E350 oil drain plug is a pain to remove, because it is covered by a large shroud, which must first be removed.
Filter is at top front of engine.
Oil change at local MB dealer is $170+.
I can do Mobil 1, with German MANN filter for $49.
Reports I have read, claim that the little pump actually gets all the oil out, just like the drain plug.
Lucky you.....My Kubota BX 25 only has one drain plug.
And for marine engines you would do what?As a prior professional mechanic I would never advise sucking the oil out of an engine unless it has no drain plug. This method will leave sludge and perhaps metal shavings in the bottom of the oil pan. While I understand the mobility issues because I have them, the only proper way to change the oil is to first bring the machine up to operating temperature and only use a box end wrench of the proper size to remove the drain plug. Oil is your engine's life blood, nuf said.
