Easy Peasy self oil change
   / Easy Peasy self oil change #22
I am 80, so crawling under is far from easy anymore.
I have used this exact same E-bay pump for several years now.
My MB E350 oil drain plug is a pain to remove, because it is covered by a large shroud, which must first be removed.
Filter is at top front of engine.
Oil change at local MB dealer is $170+.
I can do Mobil 1, with German MANN filter for $49.
Reports I have read, claim that the little pump actually gets all the oil out, just like the drain plug.
One thing Mercedes-Benz does especially well is their dip stick tube run to the bottom of the crankcase pan. Next time try making a fitting to go over the dipstick tube rather than push a tube down inside. Suck all you can out my way, then put your tube down the way you have done in the past. I don't think you will get any more out.
Putting a plastic tube down the dipstick tube is problematic for other makes. Some say it works on my Subaru, others not. One thing for sure the dipstick tube does not run to the bottom of the pan and as a result putting a plastic tube down may curve when it exits the dipstick tube and never reach the bottom.
The problem with the Subaru is the drain bolt is large and angled toward the left front wheel. Oil gushes out. Splashes. Mess. Have installed a Fumoto Valve so now I attach 8" of 1/2" vinyl hose routed into my drain pan then open the lever on the Fumoto. Drains slower but no mess.
I guess no one thing works on every possibly conceivable machine made by mankind over the past 200 years in every country and even individually manufactured machines.:cry::cry::cry:But there are some accessories that will work great or good or fair on some of the thousands of different machines made. I've even experienced the same thing with implements/attachments.
I currently own 4 Kubotas and one of them, if not more since I didn't go check the others but recently did the oil change on the MX5400 so remember it does have the split oil pan with 2 drain bolts. I'm thinking my other 3 have single drain pan bolts but I may be wrong, have been before and sure I will be again from time to time.
Anyway I hope a few people will possibly be helped by this information I provided. I also use the battery operated "stick it down in can" fuel pump to transfer my $1 off per gallon of up to 35 gallons in my 5 gallon containers of gas/diesel fuel from Krogers for cars and diesel operated machines. I bought a couple from Sears marketplace sellers for $8 each last year but now least expensive seller is $13 and same one sold by Harbor Freight and multiple other sellers. They work good for auto gas and emptying the 5 gallon container I sit on my hood on the MX and usually can pour from containers into mowers and RTV with the flexible nozzles I have on my 5 gallon containers.
It's like Pat's and other 3ph quick hitch arms that work for some but others don't like em.
I also have learned how to scroll past posts that don't pertain to me and not get offended or even reply to how they don't help me with one of my specific machines. But that's just me and my strange ways and ideas. :) :)
   / Easy Peasy self oil change #24
The tube on the DR extractor is fairly stiff, yet it was the one that curved on me on the Mz3. The tube on the Ironton pump has no stiffness. Could easily curl.
I've been so impressed with this post and others input that I ordered another one of these pumps for my barn to fuel Kubotas with it instead of hefting 5 gallon canisters up to the hood of my MX.
   / Easy Peasy self oil change #29
As a prior professional mechanic I would never advise sucking the oil out of an engine unless it has no drain plug. This method will leave sludge and perhaps metal shavings in the bottom of the oil pan. While I understand the mobility issues because I have them, the only proper way to change the oil is to first bring the machine up to operating temperature and only use a box end wrench of the proper size to remove the drain plug. Oil is your engine's life blood, nuf said.
   / Easy Peasy self oil change #30
And for marine engines you would do what?
They do have drain plugs.... that are usually inaccessible.
2020 Tiger Turf Mower, Model 3TT11-61V-37BV-EF1, S/N R1000298, Asset# 60 (DOES NOT RUN - NEEDS (A59076)
2020 Tiger Turf...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2012 Ford Expedition 4x4 SUV (A56859)
2012 Ford...
