EarthForce EF-5 enhancements
/ EarthForce EF-5 enhancements #101
Re: Name the EF-5 Contest
You don't need to call the machine anything when you're on it. And when you can't be on it 'cause something is wrong you will be calling it [censored], or PITA, or something like that.
/ EarthForce EF-5 enhancements #102
[pink]<font color=red>LOL</font color=red>[/pink]
(Muhammad, bet you'd never have guessed you'd get a request for pink text on this board) /w3tcompact/icons/laugh.gif
/ EarthForce EF-5 enhancements #103
<font color=blue>TooLongusPostoris</font color=blue>
Wait, I thought we were naming the tractor not the owner /w3tcompact/icons/smile.gif
/ EarthForce EF-5 enhancements #104
/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif
Your turn is coming... /w3tcompact/icons/wink.gif
Re: Lights
Well, here's a picture of one set of lights on the EF-5 lit up, in bright mode. This is basically what you would see if the turn signal was on and the brake lights were on.
The picture was obviously taken with flash, so that gives you a bit of an idea how bright the lights are...
Re: Lights
Here's another, taken from the back. The lights are somewhat directional, so they're a lot brighter here because you're looking straight at them, and the camera is closer. It's hard to tell because of the overload, but the top light is the red brake light, and the bottom one is the amber hazard light.
/ EarthForce EF-5 enhancements #108
Re: Lights
Holy crap, Mark!!! /w3tcompact/icons/shocked.gif
I dimmed my monitor and still had to squint. /w3tcompact/icons/cool.gif
I'm starting to understand the tonnage of candlepower them LED's are putting out, but with regards to using them as a backing-up warning device, is there any chance you could take similar pictures while the tractor is in direct sunlight?
Not trying to challenge their worth, fer sure, but now I'm just plain curious.
Re: Lights
Sure, Harv, I'll try to do it tomorrow morning...
As far as using them for a backup device, I don't think they'd work in daylight. At the very least, the unintended victim would need to be facing the tractor... Now, at nighttime, it's a different story - they light up the night!
/ EarthForce EF-5 enhancements #110
Re: Lights
That indeed would be an eye catcher if one was to come upon you Mark while traveling at night. /w3tcompact/icons/shocked.gif
So what new device shall be next. /w3tcompact/icons/wink.gif
If your dealer wanted to sell more EF-5's,he should contract you in some form and show your EF-5 at his dealership or events.
You done a heck of a job w/your own personal touch,and I given others many ideas.
/ EarthForce EF-5 enhancements #111
Re: Sound deadening
If Global doesn't have it <A target="_blank" HREF=https://www.chdist.com/ecommerce/eComm?template=product&tran_id=8&ship_no=-1&prod_id=702&prod_name=Anti-Fatigue%20Mats&parent_id=0>C&H</A> does.
A softer mat will likely dampen sound and conform to your floor better /w3tcompact/icons/smile.gif
Re: Lights
Harv - Ok, here's the picture you requested. Actually, it's a little worse-case than you requested. The sun is not just shining, it's shining directly into the lights(about 3 p.m.). You can tell that by looking at the lights on the right, which are not on, and from the reflection in the rear glass.
Unfortunately, I've now run into a limitation with the camera. The difference in brightness is still very large to the naked eye - it still hurts to look directly at the amber one (the one that's on, of course) from a distance of 20 feet (I stepped it off this time). But, the main difference you can see in the picture is that the amber reflects ambient so much better that you can the red illumination shows up better than the amber.
Re: Lights
Not too sure what happened on that last one. Let's try it again...
Re: Lights
Another picture of the lights with the sun directly on them.
Re: Lights
Here's a close-up. In this picture, the amber light that's in the lower left, the factory turn signal, is on - it's a 21-watt incandescent.
Re: Sound deadening
Andy in NH - Thanks for the link to the sound absorbing materials. I think I'm going to order some of the headliner stuff for my ROPS, too. I think it would help a lot. I'm looking for something a little more substantial for the floor, though - something that has a rubber or vinyl floor-mat type surface.
Re: Lights
Thomas - <font color=blue>So what new device shall be next.</font color=blue>
Well, not counting the air shock for the seat, which I hope to have in a day or two, and wiring the lights and rigging a circuit for hazard warning lights and turn signals, I'm planning on several things: a bunch of gauges, probably connected to a PLC of some sort, a (wireless, hopefully) tilt indicator for the bucket, and some other ideas I haven't fleshed out yet... There will always be something to do, though. /w3tcompact/icons/wink.gif
/ EarthForce EF-5 enhancements #118
Re: Lights
Mark -
For some reason I lost track of this thread there for a while, but I took a look at your daylight shots just now and dang, them babies is bright. /w3tcompact/icons/shocked.gif
Anybody with eyeballs should have no trouble noticing you coming at them, but I guess they would at least have to be facing you. Now, if you wanted to dance a laser beam out the back, you could probably get their attention no matter which way they were facing. /w3tcompact/icons/cool.gif
/ EarthForce EF-5 enhancements #119
Re: Lights
<font color=blue>...a (wireless, hopefully) tilt indicator for the bucket...</font color=blue>
Would you be thinking of an edge reading type of indicator to tell you what angle your bucket is at? I've been looking for the same thing for the fork assembly on my 'bota. Don't know as I need a remote though. 'Course if you really wanted to get carried away I could see a sensor array/w3tcompact/icons/cool.gif on the backhoe to give you depth below ground. Oh yeah - and a GPS accurate to inches, and.....
/ EarthForce EF-5 enhancements #120
Re: Sound deadening
The floor mats are not meant for a finished surface - they are designed to be installed below the floor covering of your choice. Now a burled maple floor /w3tcompact/icons/wink.gif (what the heck, with all the other embelishments you could be the first one to have a tractor with hardwood floors!) might be a bit noisy but one of those insutrial mats on top of that sound deadining mat might be just the trick.
2010 Kenworth T3 Class 7 Flatbed, 4x2, w Tuck-Under Liftgate (A63689)
2010 Kenworth T3...
Four (4) TAG Excavator Couplers (A65640)
Four (4) TAG...
Speed Trailer (A64194)
(4) Lion Hart 265160/18 Tires (A64127)
(4) Lion Hart...
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
