Earth Tubes: How to build a low cost system to passively heat and cool your home
   / Earth Tubes: How to build a low cost system to passively heat and cool your home #31
A heat exchanger would be a good idea.. Adds complexity and cost though.
   / Earth Tubes: How to build a low cost system to passively heat and cool your home #34
The system in the pictures is nice. But it is not consistent with the low cost criteria in the title of this thread.
To me, putting part of the system under the building is a mistake. Put it under a lawn, a field, or even the parking lot, but under the building guarantees that there will be disruptions for repairs.
   / Earth Tubes: How to build a low cost system to passively heat and cool your home #35
This sounds like an interesting project, I think it would be better with smooth wall pipe, so water would not set in the ridges of the flex pipe. If your hill is steep enough, this may not be a problem.
You could get a peice of the flex pipe, and set up a model, and experiment on how much of a slope is needed for complete drainage.
Dave
I agree, the corrugated pipe will make it difficult to remove all the water by gravity drain. Forced air would be the best choice or use smooth wall pipe.
   / Earth Tubes: How to build a low cost system to passively heat and cool your home #36
I second the thought of using smoothwall pipes. Also I wonder what will happen with precipition that soaks in ground? will it reach your passive pipes? Will you improve drainage with stone? Will you have some sort of cap to keep above ground water that leaches down from touching your tubes? whats the frost line in your area and will the soil still be 50 degrees near the frostline?
Passive heating shounds like a good idea- but wonder on the effectiveness?
SUV (A59231)
SUV (A59231)
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
7 30 inch reels (A59228)
7 30 inch reels...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
