E130 carburetor
/ E130 carburetor #1
Snuffy77
John Deere E130 Lawnmower
Does anybody know where I can buy a replacement carburetor fo4 the E130 that is not $100 or $200? I have seen several $30 or $40 replacement carbs, but none for the E130. Ebay shows one, but it isn’t the right one. It shows two butterfly chokes and mine only has one. My carb is a Briggs and Stratton 593198.
/ E130 carburetor #2
I would buy the OEM carb. Or fix the old one. Issue? Knock offs are a crap shoot. I've seen many get burned by them. It may or may not work good new. In a year, toast. BTW, that is not the Briggs service part number. If you'd like, post the model and type from the valve cover on the engine.
/ E130 carburetor
/ E130 carburetor
Thanks for your help. So is it 44N677? I messed up the float and a couple of gaskets. I think I will try a rebuild kit first.
/ E130 carburetor #5
44N677-0049-G1 You may want to find an IPL to source exactly what you need. Here's what I can tell you from the Power Distributors site. 597126 is the carb assy. 694914 is the float. 594212 to new # 84001917 is the kit, but shown as back ordered. SO is everyone out of stock, I dunno. Deere could be a good source with their part number or maybe another has it in stock. Internet part suppliers are good to say in stock, but then you get the email 3 days later...You may also want the intake seals as well. 594209 x2
/ E130 carburetor
Thank you very much for your help and insight. I will keep searching.
/ E130 carburetor #7
You can get a complete OEM carburetor from the Briggs and Stratton store for $177.75.
/ E130 carburetor #8
How do you know you need a new carb?
And after looking at the prices for a new carb, one would think that they are gold plated.
/ E130 carburetor #9
I had one of these that had a surge that I felt was an issue with an air bleed that I just couldn't get. Frustrating when that happens.
/ E130 carburetor
Yeah, I ordered a rebuild kit instead. Hopefully, that will fix the problem without laying out so much money.
/ E130 carburetor #11
Not so much money if having your E130 running well again. Good luck with the rebuild.
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F-250...
2012 Ford F-150 Pickup Truck (A64194)
2012 Ford F-150...
2022 EZ-GO ELITE...
2018 BOBCAT T740 SKID STEER (A65053)
2018 BOBCAT T740...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
Kivel Quick Hitch Skid Steer Attachment (A64553)
Kivel Quick Hitch...
