E130 carburetor
/ E130 carburetor #1
Snuffy77
John Deere E130 Lawnmower
Does anybody know where I can buy a replacement carburetor fo4 the E130 that is not $100 or $200? I have seen several $30 or $40 replacement carbs, but none for the E130. Ebay shows one, but it isn’t the right one. It shows two butterfly chokes and mine only has one. My carb is a Briggs and Stratton 593198.
/ E130 carburetor #2
I would buy the OEM carb. Or fix the old one. Issue? Knock offs are a crap shoot. I've seen many get burned by them. It may or may not work good new. In a year, toast. BTW, that is not the Briggs service part number. If you'd like, post the model and type from the valve cover on the engine.
/ E130 carburetor
/ E130 carburetor
Thanks for your help. So is it 44N677? I messed up the float and a couple of gaskets. I think I will try a rebuild kit first.
/ E130 carburetor #5
44N677-0049-G1 You may want to find an IPL to source exactly what you need. Here's what I can tell you from the Power Distributors site. 597126 is the carb assy. 694914 is the float. 594212 to new # 84001917 is the kit, but shown as back ordered. SO is everyone out of stock, I dunno. Deere could be a good source with their part number or maybe another has it in stock. Internet part suppliers are good to say in stock, but then you get the email 3 days later...You may also want the intake seals as well. 594209 x2
/ E130 carburetor
Thank you very much for your help and insight. I will keep searching.
/ E130 carburetor #7
You can get a complete OEM carburetor from the Briggs and Stratton store for $177.75.
/ E130 carburetor #8
How do you know you need a new carb?
And after looking at the prices for a new carb, one would think that they are gold plated.
/ E130 carburetor #9
I had one of these that had a surge that I felt was an issue with an air bleed that I just couldn't get. Frustrating when that happens.
/ E130 carburetor
Yeah, I ordered a rebuild kit instead. Hopefully, that will fix the problem without laying out so much money.
/ E130 carburetor #11
Not so much money if having your E130 running well again. Good luck with the rebuild.
PULL TYPE YARD SPRAYER (A64278)
PULL TYPE YARD...
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
2012 FREIGHTLINER M2 6X4 T/A ROLLOFF TRUCK (A66091)
2012 FREIGHTLINER...
1993 Transcraft DTL140W2 38Ft 60 Ton Spread Axle Step Deck T/A Trailer (A64194)
1993 Transcraft...
2014 Kenworth T370 21ft. Flatbed Truck (A64194)
2014 Kenworth T370...
