Duplicate Posts
/ Duplicate Posts #1
CompactTractorFan
Super Member
Pennsylvania
Kubota BX25
We seem to be having an issue with duplicate posts. Not only I have seen a lot of repeat posts by other members, but it is happening to me too. When I go to make a post, a window appears asking me if I want to stay on or leave the page (which I must do to make a post), then it posts double. This does not happen with all posts, only some.
Might want to look into it when you get a chance. :thumbsup:
/ Duplicate Posts #2
When it ask me to stay or leave I just leave and it post but you cant usually see it until you get out and go back into it.
/ Duplicate Posts #3
I've seen the warning window Kyle mentioned, but I didn't get a duplicate post. It did take forever to complete the update though.
PH
/ Duplicate Posts #4
Yep same thing, not every post but some.. I have been going back and deleting the duplicate post lately.
James K0UA
/ Duplicate Posts #5
James K0UA
And of course there's a time limit during which you can edit or remove your post. Otherwise, click on the little triangle in the lower left corner to "Report Post" and just type something like "double posting" or "duplicate post" and a moderator will remove it.
The double posting has only rarely happened to me, but it has happened, both before and after the latest upgrade.
/ Duplicate Posts #6
Seems to me the "delete post" function disappeared with the new format.
Did I miss something?
How do you delete posts now?
/ Duplicate Posts #7
edit post.. go advanced. the delete box is up at the top.
James K0UA
/ Duplicate Posts #8
That's odd....it's right where it always was in the image, although k0ua sees it at the top in the go advanced window. I looked all over for it and could not find it the other day.
I think the pages load differently at different times. For example right now i'm using IE and I'm unable to go from "my profile" to "todays posts"...just won't work. I don't have a problem with firefox everything works good, although I still get the subscribe/register prompt everytime and have to close it even though I'm already a member.
/ Duplicate Posts #9
Like James, I have just been deleting them; happens every once in a while for me.
/ Duplicate Posts #10
What about the mobile app? How do you guys go about deleting posts on it? I'm on a Droid X and can't find anything in the app in regards to deleting a double post. I guess one could use the open in browser button and do it through the main site, but I just think there would be a way to do it from inside the app somehow.
/ Duplicate Posts
Yeah, I have been just deleting them too. Just thought I would give the moderators heads-up. :thumbsup:
/ Duplicate Posts #12
It shouldn't be happening... because there's a built-in feature that prevents duplicate posts. if you see any others, please link to them so I can check.
/ Duplicate Posts #14
/ Duplicate Posts #15
/ Duplicate Posts #17
There is plenty of them. I get that popup about once a day or so. I sometimes get the dbl post and sometimes not? I always click nav away.
http://www.tractorbynet.com/forums/oil-fuel-lubricants/247409-ford8n-antifreeze.html
These are from the same guy too! He is one of out top posting members too so i doubt he is trying to screw with the board. OR is this his plan to boost his message count? hahah
Post #39 &40 I then mention it in post #41. And soundguy explains in #42
Post #69 & 70
Here you go post #76 & 77 then i joke with him about it and he acknowledges it was not his fault.
/ Duplicate Posts #18
Like we have said, its linked to that pop-up window that you get sometimes when you hit post reply. ITs only maybe 3-5% of the time?
/ Duplicate Posts #20
happening to me about 1 in 10 posts.
no idea why..
MAC FLAMELESS HEATER (INOPERABLE) (A68842)
MAC FLAMELESS...
2012 DIAMOND T TRAILER GOOSENECK TRAILER (A67714)
2012 DIAMOND T...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2014 Ford F-150 Ext. Cab Pickup Truck (A66736)
2014 Ford F-150...
2003 Sterling L7500 S/A Day Cab Truck Tractor (A66736)
2003 Sterling...
TORO SGR-13 STUMP GRINDER (A67714)
TORO SGR-13 STUMP...
