Dump trailer
/ Dump trailer #1
Peter 315
Super Member
NH
Kubota L3800 HST Kubota L47 TLB
Hi, I was wondering if anyone can tell me, is there enough oil in the reservoir on a Kubota L3800 to run a dump trailer with a single acting piston 3x24" stroke? Any input on your experience with this would be helpful. Thank you
/ Dump trailer #2
A few things.. if you don't get it to the level where it might starve the pump it would be bad, but short of that, usually when your dumping, your not driving.
If your cyl on the trlr is actually double acting with a vent in the "other end", you could make it double acting with a return hose and the cyl. would become a mini reservoir with the returning fluid going back to the tractor.
I did this on a trlr. with some qc couplers. I could switch back and forth from the tractor to the elec pump for use with the truck.
/ Dump trailer
I think the piston should use about 3qts of oil to extend but then I would be pulling the tractor forward with the trailer body up.
/ Dump trailer #4
With a little "plumbing", you can find out:D I would guess that 3 quarts would not put you in any danger to pull up a few feet. What does your hytrans take (gals) to change?
/ Dump trailer
6.2 gal trailer has one hose i could make it double acting
/ Dump trailer #6
Is the on-board pump on the trailer not working?
/ Dump trailer
no pump just one wet line
/ Dump trailer
Woodsman.jpg 5x8
/ Dump trailer #9
I bet that 3x24 piston doesn't have much more displacement than the 3pt lift cylinder. (That's the only other single acting piston on your tractor right?) And the system certainly deal with that "lost" fluid.
Bottom line: I think Rusty is correct and it won't miss those 3qts.
/ Dump trailer
Thanks cylinder calculator shows 0.7343 gal = 2.9 quarts should work dont want to burn out pump
/ Dump trailer #12
I lost 4-5 gallons with a blown cooler line (hst) and was able to drive back to the house to make repairs. You should be fine with a few quarts missing.
/ Dump trailer #13
I have this issue with a sizeable single acting hoist. It is so close that whether the pump goes into cavitation or not, depends on the position of the loader and 3PH. Not a good arrangement.
/ Dump trailer #14
I'm running a 4" x 24" on our 4' x 8' Country Mfg. dump cart powered off the rear remotes on our B2910.
No problems here, so I'm guessing you'd be ok.
/ Dump trailer #15
I'm running a double acting 4x48 off the remotes of mine without problem. I wouldn't be the least bit worried about 3 quarts. If you are concerned, do the math on how much fluid the loader uses to be at max height with the bucket dumped compared to on the ground with the bucket curled all the way back. I'm sure that would be a similar number.
/ Dump trailer #16
With a double acting cylinder you only have to make up the volume occupied by the rod. With a single acting cylinder, you also need to make up the volume of the whole cylinder.
Our B7500 has issues running the cylinder on the dump wagon (single acting 5 or 6x30ish?) but the L3830 has no problems with it.
Aaron Z
/ Dump trailer #17
Aaron Z
Yes, that's why I made the loader reference. With the loader compared to his dump wagon there are 4 cylinders vs the one. Accounting for a 1.5" rod, 4 DA cylinders would have the same fluid displacement of one 3" SA cyl on the base end for a given stroke length.
/ Dump trailer
I will make it a double acting piston then it will use about 1 qt of oil to be on the safe side a hose is cheaper than a new pump
/ Dump trailer #19
Peter 315 I believe you are doing the right thing. And I am sure your math is correct given the price of a pump.
Long 1838 (A64119)
Long 1838 (A64119)
UNUSED TAG BTB12518 - 18" PIN ON BUCKET (A64280)
UNUSED TAG...
2019 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A61572)
2019 Toro...
2017 Cat 316FL Excavator (A62679)
2017 Cat 316FL...
UNUSED SDLANCH RIDE ON SKID STEER (A64280)
UNUSED SDLANCH...
120in. Fork Extensions (A61572)
120in. Fork...
