Dump Trailer with b3200?
/ Dump Trailer with b3200? #21
On the B3300su I kept ledge-pack to 2yards and loam to 3yards. With the MX4800 it's 3 and 4+ yards respectively.
If I'm dumping onto the downhill (driving uphill) I drop the 3pth to the ground before dumping. If the hitch is flipping up with enough force to damage the lift cylinder or significantly lighten the rear end then I would assume the trailer was loaded way to tail heavy or the operator did something silly like backing up while dumping.
Just my experience with HST machines.
Gordon, I might have a different opinion on using the 3pth instead of the drawbar on a geared tractor. But as far as having the ability to safetly maneuver and stop the load... My opinion is that you'd be fine even with 4 yards of gravel on already cut roads/trails. Clearly the drawbar has a greater safety margin than the the 3pth but sacrifices A LOT of convenience (without much more risk to an experienced operator). Of coarse all is just my opinion with my experience. Done a fair amount of work with geared tractors but never pulled a non-wagon trailer that I can remember.
Leejohn makes two good points. When backing up it's possible to bind the drawbar and get yourself into a "jackknife" situation. When this happens, if you keep backing up your inside rear wheel will start lifting and you're on your way to rolling over. Don't ask how I know. As for the 3pt lifting, that can create a whole other set of complications. This happened to me with a load of wood, going uphill, the load shifted aft and the tail of the trailer dug in. The result was a loss of traction that took some futzing with to get the load back in front of the trailer axle. You can limit this tendency by securing the 3pt hitch with a chain. Just make sure you make a good, secure connection between the toplink and the drawbar:
I like the idea in the picture. I took it out yesterday with a lighter load and had no issues. 4wd and medium. On dump, it put some upward pressure on the 3pt, but didn't lift it. I use one of these. Heavy Duty 3 Point 2" Receiver Trailer Hitch Category 1TRACTOR Tow Drawbar Pull | eBay
I'm now thinking of flipping it around so I can chain the D-ring to the drawbar once the trailer is hooked up. If I can keep the 3pt down, the tractor weighs enough to dump a whole load.
Thanks again for the input.
PORTER CABLE AIR COMPRESSOR (A68842)
PORTER CABLE AIR...
2014 Chevrolet Impala Sedan (A66738)
2014 Chevrolet...
300 GAL WATER TANK (A68842)
300 GAL WATER TANK...
CAT D6R Straight Blade (A68134)
CAT D6R Straight...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
