jmc
Elite Member
- Joined
- Jul 21, 2003
- Messages
- 3,236
- Location
- SW Indiana
- Tractor
- Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
Don't read this unless you have a dump or tilt trailer. Its boring.
My dump trailer lights have been acting weird, like the clearance lights flashing with the turn signal. Turns out this is a classic symptom of a bad ground connection but the separate bed throws in a twist. Took it to an expert and he discovered that since the wiring is grounded on the trailer frame, and the tail lights are attached to the separate bed, then the current must pass thru the bed's pivot point. This trailer is only used a few times a year so the pivot was rusty or dirty. He put in a ground strap between the bed and frame to fix it. Sounds like the type of thing that may happen to others eventually unless the Manufacturer anticipated it.
John
John
