Dump Trailer Tool Box
/ Dump Trailer Tool Box
Did you notice my oil reservoir for the pump ? I had an old 20# propane tank that I cut in half. Took some 10 guage sheet and welded it to the top where the pump is mounted. I was surprised how much oil to took for a six inch cylinder to press the ram to the end. There is still 2 " to the top plate for additional oil. ( minus the size of the pump under the plate ) It was fine to figure strong than be a pint short and start the process over. I was under the impression by the manufactured pumps with a gallon reserve tank attached it would be all the oil needed for the application. Shows one needs a little math calculation ( or fill and empty the hydraulic cylinder ) to make sure the quanity of fluid is sufficient for your application. I hate doing things twice !
/ Dump Trailer Tool Box #24
I added more storage space under my trailer. It is SO worth it.
PREVIEW DATES AND TIMES (A65583)
PREVIEW DATES AND...
(4) 8 LUG RIMS (1) LT265/75R16 TIRE (A64276)
(4) 8 LUG RIMS (1)...
2007 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2007 WELLS CARGO...
Blue Diamond Brush Cutter (A64126)
Blue Diamond Brush...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
