Dump Trailer Tool Box
   / Dump Trailer Tool Box #1
Agent Blue
Platinum Member
Finished my 12' dump trailer and need to build or buy a container to hold straps, battery, and electric pump. It came out as an odd shape, 27" at the rear to a front taper approx three feet in width. Anyone have any ideas on construction ( tin or aluminum ) and needed features?
   / Dump Trailer Tool Box #2
Lots of ideas: :)
I found those pictures also. The problem lies in the limited space I have to place one. I am leaning towards sheet metal bending the structure to the size of the V hitch C channels. I have acess to aluminum but would have to bolt it as I don't have a tig welder.
   / Dump Trailer Tool Box #5
Harbor freight sells (or sold) two different size boxes I used this one on my ATV trailer. Locking Steel Trailer Tongue Box
it might be big enough for the pump and battery. It is close to the size of the box on my dump trailer.
You could look it over for details on how to build or buy it.
   / Dump Trailer Tool Box #6
I built an expanded metal compartment under the bed between the
frame rails...works WELL for me. Heck I am going to expand it and make
a compartment for my tarp as well as a broom and other things
when other projects are finishe up.
   / Dump Trailer Tool Box #7
That's a great idea! How well does it hold everything in there? Does the bed bottom seal the compartment?
   / Dump Trailer Tool Box #8
When you build the tool box, keep in mind if you ever need to use a WD hitch.
   / Dump Trailer Tool Box #9
Take a look at the Bri-Mar trailers. My uncle has one and it has a tool box and spare tire all mounted under the dump bed like the one pictured above.
Chris
Artisan that is a great idea for a tarp, broom, straps, tools and anything else one could stuff in there. Never gave it a thought and with a grated bottom liner all is secure. I do need a hitch box though because my power unit is 14" plus tall and I don't want to stick it out the bottom. Ease of battery removal also a factor.
I will check HF... Had no idea they had them.
I am a little confused... What is a WD hitch ?
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
Pallet of Asphalt Hand Tools, Shovels, Rakes, Bru. (A52384)
Pallet of Asphalt...
2015 TROXELL 130BBL VACUUM TRAILER (A53843)
2015 TROXELL...
2019 TOP HAT TRAILER 20 FOOT UTILITY TRAILER (A53843)
2019 TOP HAT...
