Dump trailer hydraulics
/ Dump trailer hydraulics #61
Those at graingers are about $100 higher than the Northern Concentric. Would you pay the difference or do you consider them about the same quality?
Our company has a commercial account at Graingers so I pay a lower price than what you see. Concentric is affiliated with Haldex. Concentric AB is the former Hydraulics Division of Haldex AB and from June 16 2011 a separate listed company. Concentric is one of the world痴 leading pump manufacturers. The Northern unit will work fine for you.
/ Dump trailer hydraulics #62
Wonder how much storage is needed for a ram like this. An estimate, just curious
Going from your existing pump which has a 2-3 qt tank to the Concentric with a 2 1/2 gallon tank you will have plenty of reserve.
/ Dump trailer hydraulics #63
Your cylinder is about 288 cu inches which is 1.25 gallons. So these will work with a little extra fluid and the needed air space.
/ Dump trailer hydraulics #64
1/2 diameter Squared times ram length = cubic inches
Cubic Inches
A unit of measurement for volume. It represents an area one inch long, by one inch wide, by one inch deep.
us fl oz =
inウ * 0.55411
/ Dump trailer hydraulics #65
Sorry, forgot the PI
Default Re: Dump trailer hydraulics
1/2 diameter Squared times 3.1416 times ram length = cubic inches
Cubic Inches
Ordered and on the way
I want to have everything I need to install this during the weekend. This was in the reviews about the product. Does anyone know what this might be?
"Installed on a dump trailer, product worked great easy to install. The only negative was the outlet fitting is a special threads, had to find and order fitting from another supplier."
That is strange. Here are the specs with inlet and outlet. They are the same. The review, was he confused or is this not typical?
Top of page
Item# 10721
Ship Weight 34.0 lbs
Displacement (cc) 2.11
Displacement (cu. in.) 0.129
Flow (GPM) 1.4 at 1,600 PSI
Reservoir Capacity 2 1/2 gal.
Inlet Port (in.) 9/16 18 SAE
Outlet Port (in.) 9/16 18 SAE
HP 1.3
Max. PSI 2,500
Volts 12 DC
Max. RPM 1,750
Phase 12V DC
/ Dump trailer hydraulics #69
Top of page
Item# 10721
HP 1.3
Max. PSI 2,500
Volts 12 DC
Max. RPM 1,750
Phase 12V DC
What the fitting are is a straight thread Hyd fitting with the O ring on them. If I remember right they are a number 8 fitting. If you take that allen head plug out on the one you have it should have the same threads
/ Dump trailer hydraulics #70
Top of page
Item# 10721
HP 1.3
Max. PSI 2,500
Volts 12 DC
Max. RPM 1,750
Phase 12V DC
I think the reviewer was confused or maybe he thinks 9/16 18 SAE is a special thread. You may need a reducing bushing because your hose fittings are probably 1/2" or 3/8" on your cylinder. TSC or any hydraulics supplier should have them. Most dump and tilt trailer builders have since relocated their hyd. pumps from under the bed to inside a tongue box for longevity and easier maintenance. You may want to consider this for safety.
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
Land Pride RCR1260 (A53317)
Land Pride RCR1260...
2013 Mercedes-Benz GL 450 AWD SUV (A59231)
2013 Mercedes-Benz...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
2023 SNORKEL A46JRT ROUGH TERRAIN BOOM LIFT (A59823)
2023 SNORKEL...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
