Dump trailer crack in oil reservoir
   / Dump trailer crack in oil reservoir #1
borisvonf
Greenville SC
Jd 5500 mfwd. Kawasaki mule sx 4x4 JD5103 with 521 loader
I have a dump trailer and noticed a small crack in the top of the oil reservoir tank on top. Covered with duct tape to keep moisture out until I can get repaired. Any suggestions on repair or source for tank replacement. Thanks in advance.
   / Dump trailer crack in oil reservoir #2
Who made the pump set-up?
   / Dump trailer crack in oil reservoir #4
Some pictures would certainly help us give you some suggestions on how to fix.
   / Dump trailer crack in oil reservoir #7
Drain it, flush it out a couple times and braze it.
I'm sure it is plastic. I'd hit it with some JB Weld and keep getting up.
   / Dump trailer crack in oil reservoir #8
There are inexpensive plastic welders out there. Harbor Freight has one. Check youtube for ideas.
HF plastic welder
Woods RM660 3pt. Finish Mower (A50774)
Woods RM660 3pt...
Probst Metal Cart (A50774)
Probst Metal Cart...
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
17604 (A51694)
17604 (A51694)
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
