Dump trailer crack in oil reservoir
   / Dump trailer crack in oil reservoir #1
borisvonf
Greenville SC
Jd 5500 mfwd. Kawasaki mule sx 4x4 JD5103 with 521 loader
I have a dump trailer and noticed a small crack in the top of the oil reservoir tank on top. Covered with duct tape to keep moisture out until I can get repaired. Any suggestions on repair or source for tank replacement. Thanks in advance.
   / Dump trailer crack in oil reservoir #2
Who made the pump set-up?
   / Dump trailer crack in oil reservoir #4
Some pictures would certainly help us give you some suggestions on how to fix.
   / Dump trailer crack in oil reservoir #7
Drain it, flush it out a couple times and braze it.
I'm sure it is plastic. I'd hit it with some JB Weld and keep getting up.
   / Dump trailer crack in oil reservoir #8
There are inexpensive plastic welders out there. Harbor Freight has one. Check youtube for ideas.
HF plastic welder
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
1997 International F-4900 T/A Dump Truck (A50323)
1997 International...
2004 Ford F-350 XL (A50120)
2004 Ford F-350 XL...
2018 JLG 1932R 19ft Electric Scissor Lift (A50322)
2018 JLG 1932R...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
