Dump trailer crack in oil reservoir
   / Dump trailer crack in oil reservoir #1
borisvonf
Member
Greenville SC
Jd 5500 mfwd. Kawasaki mule sx 4x4 JD5103 with 521 loader
I have a dump trailer and noticed a small crack in the top of the oil reservoir tank on top. Covered with duct tape to keep moisture out until I can get repaired. Any suggestions on repair or source for tank replacement. Thanks in advance.
   / Dump trailer crack in oil reservoir #2
Who made the pump set-up?
   / Dump trailer crack in oil reservoir #4
Some pictures would certainly help us give you some suggestions on how to fix.
   / Dump trailer crack in oil reservoir #7
Drain it, flush it out a couple times and braze it.
I'm sure it is plastic. I'd hit it with some JB Weld and keep getting up.
   / Dump trailer crack in oil reservoir #8
There are inexpensive plastic welders out there. Harbor Freight has one. Check youtube for ideas.
HF plastic welder
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51243)
2006 FORD F750 XLT...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
1999 Toyota Camry Sedan (A50324)
1999 Toyota Camry...
1985 Toyota Pick Up Truck (A50515)
1985 Toyota Pick...
2005 KOMATSU PC400LC-7L EXCAVATOR (A51242)
2005 KOMATSU...
