Dumb question - can you offset a rotary cutter?
   / Dumb question - can you offset a rotary cutter? #1
CMV
Platinum Member
NC
Kioti NX4510HST (previous LS XJ2025H, JD 500C)
Can you offset a rotary cutter/bush hog far to the left or right adjusting stabilizers to keep it that way to make it easier to mow against fences or keep tires a little further away from drop-offs? Not so far that you're rubbing a rear tire, but enough that you're notably far to one side.
Asked a couple people this morning and they agreed "oh no! you will quickly destroy your gearbox if the PTO shaft isn't straight". Could be true, but with joints at each end I'd think that wouldn't matter. I don't see how that is any different than the shaft not being perfectly parallel to the spline - it's at an angle from the PTO spline down to the gearbox, so why would an angle to the left or right be any different?
   / Dumb question - can you offset a rotary cutter? #2
You sure can offset your mower to either side. As you see, the limiting factor is your hitch
arm hitting your tire, not the angle of your driveshaft. As you also noted, your 2 universal
joints on the driveshaft already bend quite a bit when your mower is lifted.
I just finished replacing the gearbox seal on my neighbors 60" mower.
   / Dumb question - can you offset a rotary cutter? #4
Yes, within the limits of the 3pt hitch. On my Branson there's about 6" from side to side. Since my tractor's rear tires are a little wider than my 5' rotary I usually push it over to the right so it lines up with the edge of the right tire.
The PTO shaft on a rotary is long so the angles will be mild. If you want you can measure. Fifteen degrees or less is the number I have seen for long life.
If you want the mower to stick out more you can look into a flail with side shift.
   / Dumb question - can you offset a rotary cutter? #5
You could also unbolt one of the bottom 3pt pins and flip it 180 degrees. That would give you a few more inches of offset.
   / Dumb question - can you offset a rotary cutter? #6
I would say the driveline is a limiting factor. No U-Joint likes to bend at a severe angle. It will work, but you might get unwanted vibration AND (i'm thinking) without a doubt the u-joints and bearings will wear out prematurely.
   / Dumb question - can you offset a rotary cutter? #7
Interesting idea:
Bruce
   / Dumb question - can you offset a rotary cutter? #8
What brand is that mower Bruce? I like it.
   / Dumb question - can you offset a rotary cutter? #9
I saw it on CL a couple of years ago, from a dealer, and saved the photos. No name mentioned in the ad.
Bruce
Stainless deck is nice
2025 GPS 11.5ft Utility Trailer (A56859)
2025 GPS 11.5ft...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
2015 Peterbilt 367 National Crane NBT55 5-Mast 128ft. 55 Ton Quint Axle Crane Truck (A55973)
2015 Peterbilt 367...
SKID STEER ATTACHMENT MAINTAINER BLADE (A58214)
SKID STEER...
Krause Dominator 4850-18ft (A56435)
Krause Dominator...
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
