dumb question about HST
/ dumb question about HST #101
I had another question about HST vs gear, and it hit me to ask Google's AI, since it knows everything:
(text above was highlighted by Google, with more info on each of the four items offered below the above text)
After I read the above, I was thinking that HST is best for lower power applications, but I remembered that I've rented articulated wheel loaders before. They were larger than a utility tractor, and they are HST?!?
I guess that the word "loader" in articulated wheel loader is key. A wheel loader is more focused on a single task than a utility tractor, and that task is 99% back and forth, stop, start, reverse, etc, and that is the area where HST excels.
I haven't run a front end loaded in close to 20 years, at that time they were mostly and especially in the larger ones, gear drive with torque converters and reversers.
/ dumb question about HST #102
Now that you mention it, I do remember seeing something, somewhere, about a hi/lo within ranges. Sounds pretty nice.
Most of my reading/looking has been on Branson/TYM tractors. Guessing those do not offer this or I would have read more about it...?
The TYM T224 I bought has a high/low range to the HST. Just like you say, the manual says to come to a stop before switching from one to the other. Some of the fancier deluxe models have 3 ranges to the HST.
/ dumb question about HST #103
One concern you may have regarding an HST vs Geared is having to use the pedal contantly for mowing, etc.. I'll point out, my HST has a 'cruise' lever, so that feature is a no-issue.
Regarding the power loss, I don't think I've ever ran into a problem with the power margin being so close to may me decide on HST vs Geared. The convenience of an HST far out paces Geared, of which I've owned two of in the past.
yeah, I think a lot of CUT work is perfect for HST and HST is perfect for it, while utility tractors tend to be more in the.... tractor.... application, where HST can be a negative and there's little point of having it.
I think you've nailed it. Both have pros/cons. What is best depends on the application.
As others have posted, the best plan is to have one of each! 👍
/ dumb question about HST #105
Check some videos about how the Fendt Vario transmission works. The i-HMT is a scaled down version of it.
Yes, the hydrostatic pump and motor will lockup by angling the swash plates in a way those are technically working against each other. This causes the the power to be transferred through a planetary gear and the tractor is then mechanically driven at higher speeds where the typical HST would fall on its face.
The i-HMT is actually different from an IVT/CVT. In particular, it doesn't utilize a planetary gear, but instead has a combined hydraulic pump and motor where both the body and the shaft rotate. It takes a while to get your head around how it works, but it's pretty cool, and definitely unique. It will be really interesting to see how they work over time. HST is very well proven, as are CVT/IVT transmissions, but the i-HMT I believe is all new.
Another dumb question about HST:
How do you shift the range selector with no clutch?
Guessing that the answer is just stop and keep your feet off of the Go pedals?
So I guess the follow-up question is: can you also shift ranges in geared (4-digit TYM) tractor with no clutch if shuttle and/or gear shift are in neutral? (assuming stopped, or very close)
/ dumb question about HST #107
Most HST tractors do have clutches but you can’t shift ranges while moving anyway. You have to stop completely and then move the selector.
/ dumb question about HST #108
My hydro tractor doesn't have a clutch but coming to a complete stop it will usually range shift fairly easy. Sometimes it will take a bit of playing with the forward and reverse pedals.
As far as shifting a shuttle shift tractor without using the foot clutch only way to know is to gently try and shift with the shuttle in neutral or the main transmission in neutral.
Thanks Lou-
Yeah, I don't even have a TYM tractor (yet), but was just wondering.
New tractor will replace an old Case/IH. To shift that range selector, you have to fully engage clutch. stop. slow engine to idle. hold your tongue just right, and eeeeeease her into other range.
And half the time, it still grinds a bit. haha
Well, I finally picked up a new tractor - a 4820 that had just come in. That tractor should be a great replacement for the old Case/IH that I use with a 7' finish mower or 6' bush hog.
4820 was (compared to other brands) relatively inexpensive, and I was happy to find out that TYM was offering a $1000 discount, so that was a nice surprise.
Compared to my beat up old Case/IH, the 4820 seems very nice! 👍
/ dumb question about HST #111
..Is the PTO driven by pump or by gears? I would have guessed that even on HST tractors, the PTO was still gear driven. No?
On a little machine like my TYM T224, if i'm reading the parts diagram correctly, there's a secondary output shaft on the hydrostat that sends direct power to the PTO and hydraulic pump regardless of the output speed and direction the hydrostat is running it.
/ dumb question about HST #112
That’s how all my kubotas have worked too.
/ dumb question about HST #113
PTO will have mechanical clutch or hydraulic operated clutch but is mechanically connected to the engine.
FORREST CITY ROLLING HARROW (A63291)
FORREST CITY...
2023 CATERPILLAR 320 EXCAVATOR (A62129)
2023 CATERPILLAR...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2020 International LT625 Sleeper 48" (A62613)
2020 International...
2022 EZ-GO ELITE...
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
